TPI sputtering problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2014, 10:01 PM   #1
lewit12
lewit12's Avatar
Default TPI sputtering problems
Ok guys I'm having problems with my Tpi 383..it's in a yj wrangler. I just did the swap this spring and it was running good for a week or so, then it started back firing really loud. Found out the distributer took a crap. So I replaced it with a new MSD pro billet distributer, that problem was solved (So I thought). Then about a week later there has been a sputter when you let off the throttle and then get back on it. It's ok at cursing speeds, it only seems to do it when your really getting on the gas hard. I've replaced the coil, and all new MSD super conducter wires. The whole ignition is brand new. The plugs were new this spring so I have a feeling it's not the plugs. Has anyone delt with anything like this? I'm up for all suggestions. Thanks
lewit12 is offline   Reply With Quote
Old August 23rd, 2014, 12:15 AM   #2
Nitrodave
Check fuel pressure , flow rate , and pressure regulator for leaking.
Nitrodave is offline   Reply With Quote
Old August 23rd, 2014, 12:31 AM   #3
cerial
1200PSIg Double acting
cerial's Avatar
What did it come out of? That info will help.
Lets get the cheap fixes out of the way. Pull the TPS being careful not to break the gasket. Shoot the tps with some carb cleaner flicking it open and closed a few times then reinstall. If it now runs better replace the part as cleaning it just bought you a little time.
Pull the IAC shoot it with some carb cleaner and compress the spring a few times. This is just a maintance thing to prolong the IAC. If it runs better replace it as soon as you can as it will go bad again.
Pull the hose going to the EGR solenoid and shoot some air through it removing the oil. Check the hose for leaks and replace as needed. Remove the plastic cover then the quarter sized piece of foam covering the EGR solenoid inlet. With the engine running place your finger over the inlet and rev the engine a few times. It should sputter and gag like what your describing. If it does this with nothing covering the inlet the sensor is clogged. Replace the sensor there is no easy fix or cleaning it.
You can plug in a tester. But, I have not found one yet that will show a EGR solenoid fault. Most of the time people don't realize that the part is giving them all the headaches and unnecessary replace more costly parts.
It could be a dozen other things from fuel to CPS, to the PCM itself. Shooting the parts that get gummed up and filled with oil residue and carbon is a easy start.
Old August 23rd, 2014, 06:31 AM   #4
lewit12
lewit12's Avatar
The motor came from a 91 camaro. Thanks for suggestions guys..I'll try and free some time up this weekend to pull it in and take a look at it. Thanks again!
Page generated in 0.15628 seconds with 35 queries
