What's this tj worth? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2014, 06:18 AM   #1
T-nave
Default What's this tj worth?
I'm looking for some input on a jeep I just looked at for a friend. We can't talk to the guy or drive it till tomorrow. Here is what I seen so far.
98 tj with zero rust. Flares and bumpers. Rear swing out. Looks like it's been restored.
Interior has all the normal mods with full auto meter gauges.
Soft top, soft and hard doors.
Carbed chevy small block with th350 or 400 trans.
5-7" fully adjustable long arm lift with reservoir shocks
9" high pinion rear and 9" front with HD driveshafts
2 sets of 35s with good tread on alum rims
I won't know more specs until tomorrow on gears and lockers but I'm guessing it's got both judging by the amount of money it has into it. Looks like the restore has about 15000 miles but it's CHERRY.
So assuming it runs and drives good what do you think ball park price would be?
T-nave is offline   Reply With Quote
Old August 21st, 2014, 08:07 AM   #2
T-nave
Really guys! 50 people looked at this thread and not one person had any idea of a ball park figure.
Old August 21st, 2014, 08:12 AM   #3
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
A-billion fu-fillion dollars......
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old August 21st, 2014, 08:28 AM   #4
Porscheguy
Porscheguy's Avatar
Hard to tell with out pics..... 10-15k
Porscheguy is offline   Reply With Quote
Old August 21st, 2014, 08:34 AM   #5
T-nave
I will say the paint looks pretty fresh. The guy that owns it works at a body shop and it shows. I was thinking with the perfect paint and body and the suspension and axles it was around 15. After doing some poking around I have realized the market on TJs has come down quite a bit in the last few years.
Old August 21st, 2014, 09:09 AM   #6
jbsjunk
Little Member
jbsjunk's Avatar
2K to 15K The carbed small block will be it's downfall. Unless you're going for mud. And what's in it has no bearing on what it's worth.
Old August 21st, 2014, 10:08 AM   #7
fordbronco
the ocean called
fordbronco's Avatar
The market on tjs hasn't come down really that much. I'd say they're still at their peak right now. Without pics, it sounds like a 10k jeep. Was it a southern jeep? Were any patches installed before it was "restored"?
Old August 21st, 2014, 10:21 AM   #8
T-nave
It must of been from the south or west b/c when I looked under it at some of the little pockets it still had factory paint and the bolts didn't have any rust on them either. I wish it had TPI instead of that damn carb. It would be a no brained.
Old August 21st, 2014, 10:34 AM   #9
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
With the axles 20k at least...but only if they are true hi-9's
Old August 21st, 2014, 10:43 AM   #10
I imagine they are Curries. Still, I think north of $10K
Old August 21st, 2014, 11:10 AM   #11
Between $10k - $15k, depending on how well the work was done, and quality of parts.
Its still a 16 yr old Jeep, with a carb'd motor. The carb'd motor is a red flag, its a mismatch to a high-end TJ. You do it because you don't want to spend the money and time to do a better FI motor. So its a cut corner, then what other corners are cut.
Tru Hi-9s would be far more valuable than old currie axles. Check on parts availability in the front. Is it 44 outers? There's not much purpose for a 9" front unless its 60 outers.
Old August 21st, 2014, 12:16 PM   #12
T-nave
I think they are the older currie 9". Im guessing it has Dana 44 outers b/c I remember looking at the axle joints and thinking huh seems like they would be bigger. From what Ive seen so far the craftsmanship looks to be really good. I do know thats since it was built it has only been to the dunes a couple times and road driving. Im going to look at again today and talk with the guy. Im hoping he has the paper work for the build as that would clear up alot of things.
Page generated in 0.19391 seconds with 59 queries
