XJ pops out of 4wd... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2014, 08:45 PM   #1
sealteam10
Default XJ pops out of 4wd...
I have a 96 XJ classic. It has the 4.0 with a 5speed. Sometimes when its in 4hi it will kick out. It doesn't do it in 4lo. Is there a common issue with the linkage to the transfer case??? Or is there something else it may be????
Thanks
Matt
sealteam10 is offline   Reply With Quote
Old August 20th, 2014, 11:56 PM   #2
fordbronco
the ocean called
fordbronco's Avatar
Is the jeep stock? Probably need to adjust the linkage or maybe a worn out bushing where the linkage connects to the tcase.
Old August 22nd, 2014, 02:40 AM   #3
sealteam10
Very good point fordbronco. My xj is lifted 6.5" the linkage looks stock. Is there a kit for the bushing I can buy or another linkage I can buy for a lifted xj????
Old August 22nd, 2014, 07:32 AM   #4
jbsjunk
Little Member
jbsjunk's Avatar
Be stupid not to do this kit and be done. Pitch the stock linkage and put in something positive.
Boostworks
Old August 22nd, 2014, 07:44 AM   #5
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Boostworks
You can build that quite a bit cheaper from McMaster Carr, minus the fancy bracket.
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old August 22nd, 2014, 07:56 AM   #6
jbsjunk
Little Member
jbsjunk's Avatar
I built mine that's the same as that and a custom arm for $5
Old August 23rd, 2014, 01:41 AM   #7
sealteam10
I really like the custom linkage but it says it is for an automatic and I have a 5 speed. Will it still work???
Old August 23rd, 2014, 06:53 AM   #8
jbsjunk
Little Member
jbsjunk's Avatar
If need be, you can go to the hardware store and get a 12" piece of 3/8x24 threaded rod and make up any difference. I think there's room in the linkage for it, but not knowing the length difference would see the extra piece of rod is handy.
Page generated in 0.25910 seconds with 47 queries
