wide trac axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2006, 08:38 PM   #1
sandmaster
sandmaster's Avatar
Default wide trac axles
i ve got a set of axles that were removed from a project that was never finished
rear axle is a ford 9 inch that was shortened to jeep cj wide trac spects.
this is the large bearing housing complete with the large drum brakes. this was a new reuilt axle that was never run. will be checking on the gear ratio this weekend as im not sure what it is.
front axle is a dana 30 with some upgrades.
hd shafts all new dana 44 brake hardware and calipers with six bolt hubs and lockouts. this axle was also built and was never run. i ll get the ratio same time i find the rear.
these were part of a project i obtained and was going to finish but plans changed. asking 600.00 for the pr
sandmaster is offline   Reply With Quote
Old November 22nd, 2006, 08:52 PM   #2
trail junkie
Guest
Posts: n/a
Let me know when you get the gear ratio's, I am interested but would need to peddle my axles
Old November 24th, 2006, 09:58 AM   #3
sandmaster
sandmaster's Avatar
gear ratios are ford 9 have two available 3.54 or 5.43
dana 30 3.54 or 2.73
Old November 24th, 2006, 10:21 AM   #4
trail junkie
Guest
Posts: n/a
how much for the 30 with hd shafts, or would ya sell the shafts????
Old November 24th, 2006, 07:28 PM   #5
sandmaster
sandmaster's Avatar
selling the pr of axles as a pr as of right now
Old November 24th, 2006, 07:31 PM   #6
trail junkie
Guest
Posts: n/a
Let me know when ya change your mind
Thanks Josh
Page generated in 0.16875 seconds with 41 queries
