ujoint maintenance intervals - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2014, 08:15 PM   #1
Torg38
TorgFab
Torg38's Avatar
Default ujoint maintenance intervals
How often are you swapping out ujoints? My set of spicers 5-760x rusted up and started to get tight after about 14mo of wheeling? Should I just expect to swap them that often? Or Should I install with better grease? What are you guys doing? I power wash the truck after every outing and nut and bolt before every pre trip. Something I'm missing on my maintenance?
Torg38 is offline   Reply With Quote
Old August 17th, 2014, 08:43 PM   #2
landj
GLFWDA,UFWDA,SOFO,MEMBER
landj's Avatar
Green Grease. Autozone has it. Full Synthetic.
landj is offline   Reply With Quote
Old August 17th, 2014, 09:01 PM   #3
jaysusr
jaysusr's Avatar
X2
Old August 18th, 2014, 01:13 AM   #4
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I've never had dana 30 joints last that long. Lol
I personally stay away from greats able ujoints and only run spicers.
Old August 20th, 2014, 04:24 PM   #5
Torg38
TorgFab
Torg38's Avatar
So when installing the new joints are you adding grease to the joint? Or just install as out of the box? I'm using non greaseable for strength.
Old August 20th, 2014, 04:35 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
Schaeffer moly grease
Old August 20th, 2014, 05:32 PM   #7
wilinsonlevi
Team Thumbs Up
Install as they are.
Old August 20th, 2014, 05:34 PM   #8
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Agreed. We use Spicer joints from DTS.
Old August 20th, 2014, 07:53 PM   #9
Unless you are jumping up to Super Joints, go with Spicers only. Yes, add extra grease. DON'T POWER WASH THEM. You will force water into them.
Page generated in 0.27833 seconds with 50 queries
