NP231J tcase XJ vs YJ/TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2014, 08:26 PM   #1
swampjeep
Swamp Stomper
swampjeep's Avatar
Default NP231J tcase XJ vs YJ/TJ
I know these came in 21 spline and 23 spline, but is the bolt clocking the same?
wanting to put one from an XJ with AW4 onto an AX15 out of a TJ or YJ.
Will I need a clocking ring?
any other differences?
I've heard mixed answers, don't have the items sitting here to compare.
swampjeep is offline   Reply With Quote
Old August 17th, 2014, 09:07 PM   #2
Gunsworth
Gunsworth's Avatar
Clocking is the same on the actual cases (xjs are different only because of the mounting on aw4 side). Ive heard of different length shafts over the years too. Might be best to swap your input to be safe, at least compare them.
Old August 18th, 2014, 08:03 AM   #3
swampjeep
Swamp Stomper
swampjeep's Avatar
well, I'm asking because my nephew is in Chicago, with an 87 YJ, he needs a 23 spline NP231J for an AX15 he has swapped into the YJ, I have one out of an XJ, trying to verify if it is worth sending him, since the 2 are not siting near each other to compare. I figured I would be able to get a better answer from some of the experts here.
I wanted to search it, but since the search isn't currently working...
Old August 18th, 2014, 09:30 AM   #4
The input shafts lengths are different I believe. Otherwise the same.
There are short (1.2" from mounting face), medium (1.7"), and long (2.1") input shaft lengths on the NV231.
The AX15 usually takes the 23 spline short input shaft style.
23 spline AW4s take a medium length input shaft.
Old August 18th, 2014, 09:30 AM   #5
http://www.novak-adapt.com/knowledge...nput_gears.htm
Old August 18th, 2014, 02:48 PM   #6
swampjeep
Swamp Stomper
swampjeep's Avatar
Thanks, that is exactly the info I was needing.
Page generated in 0.16638 seconds with 41 queries
