TJ: Noon question, remove cat on 97 TJ 2.5? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 15th, 2014, 03:52 PM   #1
knaffie
knaffie's Avatar
Default Noon question, remove cat on 97 TJ 2.5?
My Mom has a 97 TJ and dealer is telling her it needs a new cat.....way too expensive for a 5000 mile/year play vehicle. Can I hollow it out and buy a fooler for the rear sensor?
Sent from my XT1080 using Tapatalk
Old August 15th, 2014, 03:58 PM   #2
joe_jeep
welfare wheeler
joe_jeep's Avatar
I gutted the cat on my 97 tj 4.0L.
No 02 fooler was needed.
Had a header and cat back.
Gutted the cat on my roommates 95 4cly yj.
No 02 fooler needed.
If you do get a cel code. Put a spark plug non fouler over the 02 sensor.
Should fix it right up.
Magana flow has cheap universal cats too, if you choose that route.
Old August 15th, 2014, 04:00 PM   #3
kickstand
circling the drain
kickstand's Avatar
I gutted the cat on my 97 tj with 4.0 when it clogged. My tj did not have a post CAT o2 sensor.
I never had a problem. Run a quality muffler behind it to avoid moisture (mine originally was straight piped after the cat and when it was wet out or I was on wet trails it would act up, once I installed a muffler the problem went away)
Old August 15th, 2014, 04:19 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I have heard this, too. Anything that spaces the O2 sensor out and away from the flow. It supposedly slows the O2 switching down enough to fool the computer into thinking the cat is functioning.
Old August 15th, 2014, 04:32 PM   #5
jbsjunk
Little Member
jbsjunk's Avatar
I gutted the rattling cat on my 97 S10 with no ill effects.
Old August 15th, 2014, 05:21 PM   #6
knaffie
knaffie's Avatar
You got lucky. That usually doesn't work on that vehicle.
Old August 15th, 2014, 05:23 PM   #7
af26yrs
af26yrs's Avatar
Check around at other places for a cat instead of the dealer.
af26yrs is offline   Reply With Quote
Old August 15th, 2014, 05:37 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
Been 5 years with no problems. Even both O2's are in the stock location.
Old August 15th, 2014, 05:55 PM   #9
fordbronco
the ocean called
fordbronco's Avatar
Yes, you can gut it. It might sound silly and smell a bit different, but it probably won't throw a code. And yes, don't go through the dealer if you decide to buy a converter anyway.
Page generated in 0.27612 seconds with 50 queries
