Alternator Issues, F150 5.0 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 21st, 2006, 08:35 PM   #1
FORD FLARESIDE
6'-1" 185lb 14YO Griffin
FORD FLARESIDE's Avatar
Default Alternator Issues, F150 5.0
So.........the alternator goes out on my truck, this is a 1992 with a 130 amp alternator for plowing. For some reason no one can sell me an alternator in that amperage, the best they can do is 90 amp.
I can buy a 200 amp that fits the 5.0 for the Mustang, but will have to do some serious grinding on the case and since this unit is more then $200, I'm not to excited about doing this.
Any ideas? Do you know anyplace near Grand Rapids that will rebuild it, or sell me something that will handle my plow and dual fans?
Old November 22nd, 2006, 04:59 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
are you set up with dual batteries or are you just trying to charge one battery really fast?
Yetti
Old November 22nd, 2006, 06:38 AM   #3
FORD FLARESIDE
Just one, thousand Amper right now...............
Old November 22nd, 2006, 10:02 PM   #4
FORD FLARESIDE
.....Anybody, I'm in real need. My truck is idle until I get this resolved.
Old November 22nd, 2006, 10:05 PM   #5
Icebreaker88
Icebreaker88's Avatar
I deal with a local shop called MotorCity Reman. I found them through ebay. I pick my stuff up localy but they also ship out stuff.
586-773-2089. They have some of the best prices I have found and have lifetime warranty.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old November 22nd, 2006, 10:08 PM   #6
Icebreaker88
Here is a link to there Ebay store, but I have found that sometimes when you call them direct you can get better prices.
http://stores.ebay.com/Motor-City-Reman
Old November 22nd, 2006, 10:21 PM   #7
FORD FLARESIDE
Thanks for the help.....................
Wierd, I know mine is a 130amp, but even this place is saying that my truck should have at most a 90amp. The E series had the 130amp. I wonder if Ford did something special with the F150's during that year with the Plow package?
Old November 26th, 2006, 09:21 AM   #8
chris1044
chris1044's Avatar
just a thought - why don't you buy the internals to rebuild the 200 amp mustang unit, and put them in your case?
Old November 26th, 2006, 08:17 PM   #9
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
the mustang is just the large case 3G alt. you could even google it and find swaps. OR over at fullsizebronco.com alot of people have done teh 3G swap, they also list what cars to get them off of.
Do you know which Alt you are running?
mooseracing is offline   Reply With Quote
Old November 26th, 2006, 08:24 PM   #10
FORD FLARESIDE
I'm not sure which one I have,................I was just told a while back that my alternator was a 130 amp..........(but it has the Motocraft stamp on it)
Ford is telling me, no way, they didn't install the 130 amp on the the F150's.
Well my sollution, I found a place called A1 electric in Grand Rapids that said they can get me a 130amp alternator, and a 1000amp battery for plow trucks, with the upgraded wiring for $214 dollars. If this is the case it sounds like a great deal. (kind of sounds to cheap to me)
I will find out tomorrow.
Thanks for all of your help
Old November 27th, 2006, 12:04 PM   #11
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
I'm looking at the Ford catalog now. They show a 75 or 80 amp alt. for 91-92 F-150 5.0. If I look into 93-96 there is a 90 amp option but nothing higher.
What is the engineering number on your alternator? I think someone is feeding you a line...
Troll53 is offline   Reply With Quote
Old December 5th, 2006, 08:28 PM   #12
FORD FLARESIDE
The 130 amp alternator is in and working, but the "bolt right in alternator" was not quite what they said.
I had to grind part of the mounting bracket, and also run a tap through one of the mounting holes.
However, it does seem to handle the load of the plow motor, head lights, and dual fans.
Old December 6th, 2006, 10:58 AM   #13
mooseracing
Stuck like a MoFo
sounds like they gave you a 3G alt. they are factory 130 amps on many cars they can be found also
Page generated in 0.27478 seconds with 62 queries
