WJ: Tranny Tran Trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2014, 09:57 AM   #1
Sandals
Fucking Zen as Shit
Sandals's Avatar
Default Tranny Tran Trans
2001 WJ Limited, 4.7 auto trans
18 months ago, had Trans rebuilt and TC replaced, seemed fine for a bit, and started having previous issues again, Some slipping at highway speed (gears) occasional hard and late shifting. They took it back, looked into, made a few small adjustments but didn't find anything obvious.
Still having issues, but it's only intermittent. Not constant at all, and sometimes a shut off and cycling makes the issue go away which is making think it's possibly the transmission electronics.
Anyone else have a take on this? If i was able to easily find a Junkyard box (Haven't been able to) I would swap it and see if that cures it, but looks like only option is a new replacement and would rather noth spend a few hundred on that if it's still a mechanical issue.
My Knowledge on auto trans is limited, hence why i'm reaching out.
Old August 13th, 2014, 08:34 PM   #2
Tom
Because racecar
Tom's Avatar
No codes? How is the tps? Unfortunately there are lots of engine electronics that can cause the trans to act wacky. My guess is a problem in the valve body. They have a problem with an accumulator plate cracking.
Old August 13th, 2014, 11:25 PM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
No Codes (aside from ABS but fukc those 3 sensors)
TPS Seems fine, have yet to replace, I could, it's old enough but i almost always break one of those fucking screws.
I'm guessing valve body isn't an "in the vehicle repair" a mildly knowledgeable person can do themselves is it?
Old August 26th, 2014, 11:21 AM   #4
ricthewrench
i make everything
listen to tom, guru status.
ricthewrench is offline   Reply With Quote
Page generated in 0.20408 seconds with 35 queries
