XJ: . - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 8th, 2014, 05:05 PM   #1
jeepbrattt
New car smell.....Mmmmmmm
Default .
jeepbrattt is offline   Reply With Quote
Old August 8th, 2014, 05:12 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Is there fuel at the fuel rail on the engine? Can you hear the fuel pump running?
Old August 8th, 2014, 05:12 PM   #3
Tommy
Weekend Warrior
Tommy's Avatar
Sounds like the fuel pump burnt up from running out of gas.
Tommy is offline   Reply With Quote
Old August 8th, 2014, 05:32 PM   #4
Nitrodave
Got spark ? Maybe it really didn't run out of gas.....
Nitrodave is offline   Reply With Quote
Old August 8th, 2014, 06:56 PM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
You need to check fuel pressure also. Pushing the shrader valve and seeing fuel squirt out is not flawless indication of fuel pump condition. Next verify spark. If no spark then suspect crankshaft position sensor or cam position sensor. After that there are a number of small variables that could contribute to a no spark condition that can not be diagnosed over the internet. A way to cheat with the spark test is to spray some starting fluid in the air cleaner while someone cranks the motor. If the engine starts and runs briefly, then suspect a fuel delivery issue.
Old August 9th, 2014, 01:14 PM   #6
hghgrad
hghgrad's Avatar
Check the grounds...the strap on the back of the motor, ground at the coil, and I think there's one around the trans dipstick tube area. I had issues with the one around the trans dipstick on my xj.
hghgrad is offline   Reply With Quote
Old August 9th, 2014, 01:36 PM   #7
firehawk
Live Action!
firehawk's Avatar
replaced crankshaft sensor yesterday, fuel pump sounds good, sprayed starting fluid and still crank no start. Checked all fuses...all good. stuck a computer on it and read...cannot read pcm...swapped in a different known working pcm...same reading....
test light on wires to pcm next
Sounds like no spark then. Probably needs a sensor or computer.
Old August 9th, 2014, 02:48 PM   #8
mudrunner456
mudrunner456's Avatar
Not sure what year your dealing with but tj did this to me once. It was a coil on plug style and the magnet inside the cam sensor fell off. Cheap and easy fix. Just took awhile to find it.
mudrunner456 is offline   Reply With Quote
Old August 10th, 2014, 01:52 PM   #9
skife
skife's Avatar
bet the cig lighter fuse is blown
Old August 10th, 2014, 01:55 PM   #10
skife
skife's Avatar
ok, quit swapping parts, you need to check 2 things right now.
1. what is the fuel pressure?
2. does it have spark?
you keep swapping parts back and forth but the only thing you're checking is if that part is the bad part. right now the only symptom you have is "no start"
Old August 10th, 2014, 04:30 PM   #11
GREASYHANDS
GREASYHANDS's Avatar
Does it have spark plug wires abd a distributor or a long coil pack on the head?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 10th, 2014, 05:41 PM   #12
GREASYHANDS
Take the cam sensor off the oil pump drive and make sure that there is still a good tone wheel under there. I have seen a few that would fall apart and wreck the cam sensor and pump drive. Also check at the injectors for 12v on the green wire orange strip (I think) while cranking. If there is no power ther many of the other sensors are also lacking voltage.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 10th, 2014, 06:22 PM   #13
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Old August 10th, 2014, 06:23 PM   #14
hosejockey4506
Visiting Admin
also are you positive all the PCM fuses are good
Old August 10th, 2014, 07:35 PM   #15
Nuggets
I fix stuff!
Nuggets's Avatar
Fuel pressure is good. No spark
What is the actual number? Without this, offering advice is pointless.
Old August 10th, 2014, 08:24 PM   #16
Nuggets
I fix stuff!
Nuggets's Avatar
Like I said,.,.....I have no pressure gauge, limited tools....when I get one here I will post actual number.....
It is common that a fuel pump can run but not deliver enough pressure to start or run. I am a professional mechanic and I diagnose problems like this systematically. If you don't have a proper diagnostics you will just piss more money away than you need to. If you get the fuel pressure, I will compare it to spec and see where you stand. If good, I will instruct you as to what and how to check the next item that may be causing you problems.
Old August 10th, 2014, 08:26 PM   #17
mudrunner456
I still vote cam sensor
Old August 11th, 2014, 03:45 PM   #18
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Can you smell the fumes from the fuel coming out the tailpipe
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old August 11th, 2014, 03:46 PM   #19
Lousypirate
Whoop Whoop
Ruining it out of fuel could make the injectors stick shut
Old August 11th, 2014, 03:48 PM   #20
Lousypirate
Whoop Whoop
Pull the coil rail off and plug a spark plug into it and lay it on the head to ground. wear rubber gloves if you're going to hold onto it while doing it. The kind you women folk use while cleaning the shitter
Page generated in 0.39335 seconds with 83 queries
