96 xj no spark no fuel - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 8th, 2014, 04:00 PM   #1
bono
bono's Avatar
Default 96 xj no spark no fuel
I threw some 6" leafs on the back of the trail beater and when I went to back it off the rack it turns over but will not fire. I've tried pouring fuel in throttle body with no luck, then went and checked spark. I have power going into coil pack but nothing coming out. What is out there that will cause fuel pump not to prime and no spark? Any help is greatly appreciated. Unless you think it is a pcm I will not be happy then lol
bono is offline   Reply With Quote
Old August 8th, 2014, 06:18 PM   #2
vholdsworth23
vholdsworth23's Avatar
I can't remember if this jeep will have one but look for an ASD ( automatic shut down ) relay . If there is one try swapping it with one u know works
vholdsworth23 is offline   Reply With Quote
Old August 8th, 2014, 08:44 PM   #3
bono
bono's Avatar
Tried :/
Old August 26th, 2014, 11:22 AM   #4
ricthewrench
i make everything
crank sensor likely
ricthewrench is offline   Reply With Quote
Old August 26th, 2014, 12:09 PM   #5
bono
bono's Avatar
Already did cps turns out there were a couple wires that got melted while fender trimming
Old August 27th, 2014, 06:03 AM   #6
ricthewrench
i make everything
Cool. Ez fix
Tags
cherokee, no start, probably scrap soon
Page generated in 0.23773 seconds with 41 queries
