what to replace a 231 with - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 4th, 2014, 07:43 PM   #1
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
Default what to replace a 231 with
Broke my 231 in the XJ, is there a stronger easily swapable t case you would recommend to swap it out with.
I have been just stress cracking the cases, I dont really have enough power to break the gear set
Old August 4th, 2014, 09:22 PM   #2
firehawk
Live Action!
firehawk's Avatar
Is it possible that there is a better way to mount it or is it the landing from jumps when on the throttle?
Old August 4th, 2014, 09:26 PM   #3
hosejockey4506
Visiting Admin
Just splitting the case on the top. I will get a pic its deffinatly a stress crack not a impact problem
Old August 4th, 2014, 09:33 PM   #4
Wehan
Wehan's Avatar
Gear down the axel ratio will take stress out of the tcase. Otherwise possibly the NP241OR rock track.
Wehan is offline   Reply With Quote
Old August 5th, 2014, 03:49 AM   #5
I cracked a couple 231's near the front output. So we tig welded some gussets around it and it survived quite a while like that. I don't know if the person who bought it is still running it or not.
Old August 5th, 2014, 04:16 AM   #6
Wramblerguy
Wramblerguy's Avatar
idk about the strength of the cases
but a 241 out of a jk
208 out of a fsj
or you could always flip a d300
3rd generation jeeper
Old August 5th, 2014, 06:31 AM   #7
hosejockey4506
Visiting Admin
thats where i am breaking them, on top of the front output. Im guessing its from charging through the whoops.
honestly they last longer then expected. I just dont want to buy a atlas prior to the v8 swap and waste money on a adapter and input shaft
Old August 5th, 2014, 06:38 AM   #8
alumcj
alumcj's Avatar
NP243-AMG...anyone confirm if its a bolt in?
alumcj is offline   Reply With Quote
Old August 5th, 2014, 06:45 AM   #9
hosejockey4506
Visiting Admin
different input gear i am assuming jeep is only 23 spline
Old August 5th, 2014, 07:54 AM   #10
Bones
Bones's Avatar
have you tried to weld some ribs on?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 5th, 2014, 08:07 AM   #11
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
np207, probably should swap the tranny for the BA-10/5 that goes with it. Very stout.
JohnnyJ is online now   Reply With Quote
Old August 5th, 2014, 08:09 AM   #12
Wehan
Wehan's Avatar
No.
Old August 5th, 2014, 08:56 AM   #13
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Originally Posted by Wehan View Post
No.
zip it. it is the best combo ever. should bolt right in.
Old August 5th, 2014, 09:10 AM   #14
kickstand
circling the drain
kickstand's Avatar
Old August 5th, 2014, 11:01 AM   #15
My solution. If you look close you can see a vertical rib underneath the top one.
Old August 12th, 2014, 04:42 AM   #16
Wramblerguy
any 241 post 1998 doesnt have a speeedo option
a 241d out of a dodge would be your best bet
Page generated in 0.42005 seconds with 71 queries
