1996 xj frame boxing/bluid with 1/4 plate and 3/16 floor - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2014, 12:02 AM   #1
magauto
magauto's Avatar
Default 1996 xj frame boxing/bluid with 1/4 plate and 3/16 floor
i know 1/4inch is over kill but steel was free, to get to the piont. with all that added wieght with rear bumper,frame plating,new floor,tools parts should i be thinking on using a different vehicles rear leaf springs? i have tons of hours into all the frame peices and dont want to go back as a friend suggested to re do in 3/16. also since floor is cut out so i rosette weld from ininner uniframe rail to thicker plate?
is 1996 xj 5in lift in front
ID:	118044   Click image for larger version
magauto is offline   Reply With Quote
Old August 27th, 2014, 07:12 AM   #2
ricthewrench
i make everything
Same deal here, built a rear clip for 98xj, Frkn HD! Thinkin a higher spring rate for better susp action. Starting search now, Deaver will make, kinda $
ricthewrench is offline   Reply With Quote
Page generated in 0.14155 seconds with 30 queries
