Neutral Safety Switch on an Aw-4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2014, 11:38 AM   #1
Aquaman
Aquaman's Avatar
Default Neutral Safety Switch on an Aw-4
Any tips on how to take off the neutral safety switch on an Aw-4 transmission with out cracking the casing? I tried wood shims and I've heard using the nut as leverage but that isn't going to be good on the threads.
Aquaman is offline   Reply With Quote
Old August 1st, 2014, 09:37 PM   #2
fordbronco
the ocean called
fordbronco's Avatar
There's a lock washer with tabs on it that keep the nut from going anywhere . Fold the tabs and loosen the nut enough to get a screwdriver under it. It takes a some careful trying and prying, but you'll get it. Then you'll have to guide it off the shaft.
Old August 26th, 2014, 11:24 AM   #3
ricthewrench
i make everything
im a hillbilly, i jumpered mine, risky to remove. just sayin...
ricthewrench is offline   Reply With Quote
Page generated in 0.15513 seconds with 32 queries
