Methyl ethyl ketone for rubberized undercoating/bedliner removal? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2014, 04:01 PM   #1
Lousypirate
Whoop Whoop
Lousypirate's Avatar
Default Methyl ethyl ketone for rubberized undercoating/bedliner removal?
Is this my best bet?
I had my most aggressive options between mek and xylol.
Are these too aggressive? I was planning on trying the mek after dinner tonight.
I want to strip the unirail to put frame stiffeners on the xj. It is the rubberized undercoating.
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old July 28th, 2014, 04:03 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
A 4.5" grinder and a selection of wire wheels and cups work s pretty quick
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 28th, 2014, 04:06 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
Im betting mek would take off rubberized undercoating. Doubt it would take off quality bedliner. Mabey take off herc or rustoleum bedliner.
I used to have a can of something called strypeze. It was way old, 70s vintage.
It would remove almost any coating. Stuff was nasty! Doubt u can buy something that effective any more.
Old July 28th, 2014, 04:06 PM   #4
Lousypirate
Whoop Whoop
I am am advocate of work smart not hard. I would like to try a chemical first.
Old July 28th, 2014, 04:08 PM   #5
Lousypirate
Whoop Whoop
I did read somewhere that the quality bedliners use xylol... but I didn't feel like paying $15/qt
Old July 28th, 2014, 04:08 PM   #6
MusKegon_ZJ_gurl
Extraordinarily Ordinary
MusKegon_ZJ_gurl's Avatar
Where did you get MEK?
I've only been able to find its replacement.
http://www.glfwda.org/
MusKegon_ZJ_gurl is offline   Reply With Quote
Old July 28th, 2014, 04:09 PM   #7
Lousypirate
Whoop Whoop
Do it best hardware store.
I can hook you up, they had several gallons at the one in Sparta
Old July 28th, 2014, 04:32 PM   #8
jbsjunk
Little Member
jbsjunk's Avatar
This is the best bet. Nothing lingering. And you don't need to spend big money for chemicals. I've done a couple this way.
Old July 28th, 2014, 04:38 PM   #9
firehawk
Live Action!
firehawk's Avatar
A torch and putty knife would work for the thick stuff and then use a wire wheel.
Old July 28th, 2014, 05:46 PM   #10
Nuggets
I fix stuff!
Nuggets's Avatar
If using MEK or Xylol, do it outside and even then use a respirator and gloves that will resist the chemicals you are using. MEK is some nasty stuff.
Old July 28th, 2014, 05:46 PM   #11
Lousypirate
Whoop Whoop
Already planned for. I was at least going to do a test patch
Old July 28th, 2014, 07:12 PM   #12
Lousypirate
Whoop Whoop
No dice. Would probably be better if I could soak it. Plans to pick up wire wheels and grinding discs tomorrow
Old July 29th, 2014, 10:06 AM   #13
bbaXJ
Yooper In Training
bbaXJ's Avatar
Last night I was stripping off some of the sealant/filler used on the seams inside my TJ tub so I could do some welding. This stuff is much thicker and at least as tough as most undercoatings I've encountered. The wire wheel on my angle grinder buzzed through it no problem. Hand scraping the few areas I couldn't access with the grinder was not fun
Old July 29th, 2014, 10:34 AM   #14
Lousypirate
Whoop Whoop
What kind of grinding where'll did you use. I was going to try a flap wheel first, after I knock off what I can with wire wheels.
It all seems easily accessible
Old July 29th, 2014, 11:01 AM   #15
bbaXJ
Yooper In Training
bbaXJ's Avatar
Ah sorry, I thought I said wire wheel but I guess I bricked on that one. Wire wheel all the way, a flap disc will just melt it, clog, and fling molten rubber all over the place. Wire wheel does quick work....still messy, but at least it's effective too.
Old July 29th, 2014, 11:02 AM   #16
Lousypirate
Whoop Whoop
I'll do it outside
Old July 29th, 2014, 07:57 PM   #17
Lousypirate
Whoop Whoop
Picked up a really stiff bristled cup wheel, cleaned up way better than anticipated. Plan on cleaning it up again later in the week to weld stiffeners in Saturday.
I was expecting a horror show for some reason.
Old July 29th, 2014, 10:25 PM   #18
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I use a kerosene heated power washer for spray on undercoat.
Page generated in 0.58265 seconds with 77 queries
