WJ: Brakes in need of Viagra - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2014, 10:23 PM   #1
Sandals
Fucking Zen as Shit
Sandals's Avatar
Default Brakes in need of Viagra
2001 WJ
Rotors, Pads Calipers about 9 months old
Booster and Master cylinder 1 month old
I haven't been happy with pedal feel for some time, replaced the booster because saw a little dripping fluid and it had over 200,000 miles on it.
After all was installed I gravity bled the system, had at least 3/4 quart of fluid run through each bleeder.
Since the pedal feel has still been soft, no fluid usage, and no visible leaks.
Any ideas?
I may get another cap and do a pressure bleed to see if that changes it at all.
Old July 25th, 2014, 10:28 PM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
200000 on stock brake lines? Drum brakes?
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old July 25th, 2014, 10:30 PM   #3
firehawk
Live Action!
firehawk's Avatar
You replaced the booster, you also replaced the master?
Did you bench bleed it properly?
Old July 26th, 2014, 12:01 AM   #4
Sandals
Fucking Zen as Shit
Sandals's Avatar
4 wheel disc s
Still factory lines, maybe the soft lines are getting worn and bulging under pressure, hadn't thought of that.
Replaced master, bench bled, and then when it wasn't to my liking also followed " installed master bleeding" tricks"
Old August 12th, 2014, 06:42 PM   #5
JEFF
Hold my beer!!
JEFF's Avatar
Check the slide pins in the caliper mounts. It is very common for these to bind or get rusted onto the mount itself, two pins per side should slide free in and out. One of the two pins is probably binding and this is what makes the pedal feel soft, it will also cause uneven pad ware and most common on the front brakes. Be prepared to replace the mounts and slide pins if they are seized as it is not worth your time nor safe because you will need a bunch of heat from a torch to get the pins loose. You will need to know what type of brakes you have as the 01 GC could have two types of front brakes and the mounts are different.
good luck.
JEFF is offline   Reply With Quote
Old August 13th, 2014, 09:52 AM   #6
Sandals
Fucking Zen as Shit
Sandals's Avatar
good luck.
Nope, all calipers one year old, all slide well. Front's I converted to Akebono after the shitty Teves kept warping rotors.
I did ANOTHER Gravity Bleed while tapping the Calipers for about 15 minutes each (yes, really that long) and another 5 minutes of tapping on the MC after depressing pedal 1/4 of the way.
This made them 100% better, still not perfect, but way better, so somehow these bitches have air trapped thats not coming out more so than i have ever had before, this vehicle and others. Bastard Jeep.
Might try to find a new MC Cap and add a schrader valve to it and do a little pressure bleed while tapping to see if that gets whatever little bit is left out.
Old August 13th, 2014, 09:55 AM   #7
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
I replaced a front rubber line on my grandpas '02 WJ, it was buldging under pressure. That was after spending money on all new pads, rotos, and master cylinder
Old August 13th, 2014, 10:00 AM   #8
Sandals
Fucking Zen as Shit
Sandals's Avatar
LOL I forgot to add that, last week I replaced all 4 rubber lines at the wheels, the rear center rubber line, and the two hard lines that were so rusted i'm surprised they weren't leaking lol.
It's getting better, i just know it can be better lol
Page generated in 0.25990 seconds with 47 queries
