*fixed*727 trans experts...help! Wont shift after rebuild. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2014, 11:43 AM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default *fixed*727 trans experts...help! Wont shift after rebuild.
Its actually a 46re but I installed a transgo shift kit to convert it to full manual. No computer is needed anymore. I just have a switch to send ground to the lockup and OD solenoids.
I rebuild the trans since it was trashed.
It will not shift out of first in HI range. When I put it in Low, it will shift .... but dosn't feel rite. It will also feel as if its stuck between gear. The engine really bogs down and dosn't want to move.
Where should I start?
I called transgo and they said to check the rear servo pressure. He said it should be around 25psi in low, than drop off when in second to zero psi. I confirmed that this is happening. So this tells me the rear band isn't staying applied when its trying to apply the front band.
Maybe VB related? Could low pressure cause this?
Old July 15th, 2014, 06:49 PM   #2
Nuggets
I fix stuff!
Nuggets's Avatar
Start with line pressure and go from there. If low, then you have pump issues.
Old July 15th, 2014, 07:17 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Yea trans go said check it. Should be 75psi at idle. I'll check in a few.
Old July 15th, 2014, 08:09 PM   #4
hobbyjeep
any results from pressure test?
hobbyjeep is offline   Reply With Quote
Old July 15th, 2014, 10:09 PM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Pressure test is as follows:
*10psi at idle in drive gear
*up to 20psi at 1500 rpm
*30psi at 2000 rpm
During first test it dropped to 0 psi. Restarted the jeep after it sat for 5 mins and read pressure again.
Old July 16th, 2014, 12:55 AM   #6
Nuggets
I fix stuff!
Nuggets's Avatar
Something is screwed up in the front pump.
Old July 16th, 2014, 08:47 AM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Ill call trans go and see what they say....but everything I have read In ny books point a faulty pump.
Old July 16th, 2014, 03:54 PM   #8
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
pumpy pump
Old July 16th, 2014, 04:24 PM   #9
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
They say check the pressure regulating valve to see if it is stuck. If it is good then front pump failure.
Old July 16th, 2014, 11:30 PM   #10
Nuggets
I fix stuff!
Nuggets's Avatar
Hopefully you flushed the cooler before putting the new trans in.
Old July 17th, 2014, 12:10 AM   #11
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Wellllllll.... I found the issue...lol
Pulled the front pump housing, set it on the table and flipped it over.....bolts holding pump to support shaft thing we're loose......forgot to torque them down! So it literally could open up and let all the pressure out.
Check and double check your torque kids! I must of hand tightened to check end play and forgot about it.
Old July 17th, 2014, 12:11 AM   #12
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Also yeas I did on the trans cooler and now I also run an inline spin on filter.
Old July 17th, 2014, 08:23 AM   #13
Nuggets
I fix stuff!
Nuggets's Avatar
Glad it worked out.
Old July 17th, 2014, 08:34 AM   #14
hobbyjeep
I always like to be able to fix things without buying more parts...
Old July 17th, 2014, 09:25 AM   #15
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Good thing I didn't order the parts without tearing it apart.
I'm just happy to have found an issue that's very obvious. Always hate tearing apart stuff that dosnt work to not see any obvious issues to fix.
I'll have it back in late tonight or tmrw. Hope I didn't mess the clutches up to bad by all the slippage.
Old July 17th, 2014, 11:51 PM   #16
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
100psi at idle now :) 150psi at 2k.
Old August 19th, 2014, 03:48 PM   #17
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
So I finally got this thing fixed few weeks ago. After I had pressure like it should of been, it still would not shift. There was no governor pressure at the test port. Tech at transgo told me to shoot air through the port and look for a leak of air. Well i found a leak, it was at the governor solenoid. Messed around with it forever and changed parts, new solenoid, new gasket, new o rings, new aluminum block... still bled air. Pulled the valve body and cleaned it. Still hapend. Put it all together figure it was supose to bleed air their and they were miss informing me.
Well it worked. I imagine a valve was just stuck and the initial blast of air freed it up. I lost a week and a lot of time messing with it.
So now it shifts...but horrible 2-3 overlap. So bad it stops the jeep when driving. Called tech line again, and they run me through different things. They come to the conclusion the port in the valve body is worn and the VB is junk. So I pull it and swap the parts over to a new valve body I had.
Still had the issue. Next step was to tap the case for the orfice plug so i could thread in a brass plug with different hole size to dial it in. Did it about 4 times (mind you, you have to drop the valve body every time). Another week I still had the same problem.
While looking up what people normally drilled the plug out to at work I cam upon an image where the plug was installed i a different spot then wehre they told me to install it.
come to find out....they had me installing the plug in the WRONG HOLE! Instructions were bad. Scares me it was dated from Jan, 2011 and went this long unoticed.
Called them and gave them some words of how unhappy I am and how they greatly shortened the life of my trans I'm sure. They refunded me the cost of the shift kit and sending me a jacket.
Page generated in 0.39467 seconds with 74 queries
