Ford 8.8 in a YJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2014, 09:55 AM   #1
Mulder
Jeeper
Mulder's Avatar
Default Ford 8.8 in a YJ
The ford 8.8 has a different offset than the stock Dana 35. Should I line it up and use a wheel spacer to make up the difference on one side?
Or can my cv driveshaft handle the misalignment?
Mulder is offline   Reply With Quote
Old July 8th, 2014, 10:16 AM   #2
royalcherokee
royalcherokee's Avatar
my 8.8 has a slight offset and ive never had to change my ujoints or had any vibrations
royalcherokee is offline   Reply With Quote
Old July 8th, 2014, 10:40 AM   #3
Center the axle on the vehicle.
Old July 8th, 2014, 10:46 AM   #4
Mulder
Jeeper
Mulder's Avatar
Great thanks
Old July 8th, 2014, 11:33 AM   #5
Wehan
Wehan's Avatar
Check for diff cover to fuel tank clearance, mine whacks it when coming down off logs or ledges where the rear springs both compress and the axle travels straight up, need to get under there and clearance the tank some day. I didn't have that problem with the stock cover but when I switched to my RuffStuff cover its now an issue.
Wehan is offline   Reply With Quote
Page generated in 0.25585 seconds with 38 queries
