Gitchee Gumee 2014 Sept. 26 & 27 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old July 7th, 2014, 07:49 PM   #1
GLFWDA TRC
Trail Ride Committee
Default Gitchee Gumee 2014 Sept. 26 & 27
Its almost that time of year again! Time for Great Lakes Four Wheel Drive Associations Gitchee Gumee 2014 fall Canadian Adventure trail ride.
Click the link for the mail in registration form.
http://www.glfwda.org/docs/2014%20Gi...gistration.pdf
GLFWDA TRC is offline   Reply With Quote
Old July 10th, 2014, 08:56 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
Can't wait to go! I'll be sending in my registration in shortly.
Old July 10th, 2014, 09:42 AM   #3
phittie1100
phittie1100's Avatar
Check is in the mail
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline   Reply With Quote
Old July 10th, 2014, 11:07 AM   #4
You are paying me for this? Sweet.
Old July 10th, 2014, 11:33 AM   #5
phittie1100
No - but if you are leading a group out this year I promise to tag along with my vertically challenged Jeep again
KD8PAV
Old July 10th, 2014, 12:12 PM   #6
fsumotorhead
N8KVB
I just booked a room at Blueberry hill, no worrying about the weather and sleeping in a tent!
Sorry @
pigfat
, we won’t be able to help you put the roof back on your tent when it’s raining at 3am, we’ll be sleeping in a nice toasty room dreaming about big rocks and big boobs.
Old July 10th, 2014, 12:17 PM   #7
pigfat
GONE COMMANDO
pigfat's Avatar
Hahaha. Guess I better stake my junk a little better this year. Lolol
pigfat is offline   Reply With Quote
Old July 18th, 2014, 03:21 PM   #8
Eric99tj
Just bump it....
Eric99tj's Avatar
I am ready!
Sent from my SCH-I545 using Tapatalk
Southern Michigan Rockcrawlers
Eric99tj is offline   Reply With Quote
Old July 22nd, 2014, 08:39 PM   #9
Stil2Low
Stil2Low's Avatar
Just a heads up, the bridge by the first waterfall along the Tribag is severely rotten and most of the timber is gone from the one side underneath. If its still there I recommend to use the bypass trail. Heard the MNR doesnt even want quads running across it
Stil2Low is offline   Reply With Quote
Old July 22nd, 2014, 08:42 PM   #10
That's not a good place to fall in.
Old July 22nd, 2014, 08:52 PM   #11
Stil2Low
Stil2Low's Avatar
Just dont want to see anyone wreck their rig on the first leg in
Poor quality pic..
Old July 24th, 2014, 05:35 AM   #12
Eric99tj
Just bump it....
Eric99tj's Avatar
Hopefully someone marks it. I probably will forget about it.
Old July 24th, 2014, 05:51 AM   #13
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
It's time to see if you can kick 'Back Doors' butt this year. The spring group did some brushing so we shoud be able to run it a lot quicker (in DAYLIGHT) especially after you get your 'undercarriage car wash' in the 40" beaver pond. I'll bet they didn't 'sleep' much this year.
Is this one that has a ford on one side? Might as well get that 'bypass' broken in.
I'm also curious to see how much road is gone this year at the big bend along the Batchawana. There was a partial bypass put in last year.
jim-kb8ymf
kb8ymf is offline   Reply With Quote
Old July 24th, 2014, 05:59 AM   #14
I'm guessing that with as much snow as there was, that the spring runoff did a number on the big bend.
I'm planning on doing a combination of old and new again this year. Since I searched for years for backdoor and discovered I was within 100 ft of it once, I plan to run it this year. (with your permission ) I'm going to hit Lion's back (no one did last year) and another in-and-out trail that some of us did a few years back. Last time in we discovered a new rocky section.
One other option since I will probably not make the Loonie run this year is to run Curly's on Saturday. (gotta talk to the wife about this )
Old July 24th, 2014, 06:26 AM   #15
kb8ymf
kb8ymf's Avatar
Back door should be great this year. The guys brushed it in the spring. The only question is, which direction? The spring group did it W-E, said first river crossing and said it was a winch fest. They also said they did your 'brushy' section (where Mark and Paula nearly dropped 10 feet into the river) to avoid the water......might have to get clarification on that.
You should also try to get to Lower 2 and No Bridge if you can this year. Lower 2 has a great rocky section. Eric/Indy can vouch for it I believe.
On Thursday I'd like to see if we can find a connector under Pancake which will open up an whole new set of loops we could put together (Eric did some of the W-E work and I'd liek to see if it has any possibilities.
I'd like to push No Bridge further north. We stopped and turned around last spring due to lateness in the day. Both had possibilities and Both looked like they were logging roads in the past. The question is, did they just lead to a turn around? They're close to connecting to a east west road so that would open up again MORE loops to other trails, (Lions Back this time)
j
Old July 24th, 2014, 07:09 AM   #16
landj
GLFWDA,UFWDA,SOFO,MEMBER
landj's Avatar
Where mark and paula had to turn around did not get brushed.
The big bend on the batchawana was quite narrow.
landj is offline   Reply With Quote
Old July 24th, 2014, 11:54 AM   #17
chevotass
chevotass's Avatar
hopefully attending. waiting for clarification
Old July 24th, 2014, 12:02 PM   #18
kb8ymf
kb8ymf's Avatar
Somethings gotta give if it gets any narrower than this! And I know it will!
Name:	batchawana narrows.jpg
Old July 24th, 2014, 12:03 PM   #19
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I want to do this trip!
CHEVYRCKS is offline   Reply With Quote
Old July 24th, 2014, 12:17 PM   #20
phittie1100
I want to try to head back up that waterfall that we started then turned back - was that on No Bridge?
KD8PAV
Page generated in 0.47515 seconds with 85 queries
