highsteer knuckle fix - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 6th, 2014, 10:42 PM   #1
BIGBADJMY
BIGBADJMY's Avatar
Default highsteer knuckle fix
Well I finally pulled the jeep on hoist to fix this highsteer for good here some pics of it all tore apart n what it looked like before.
ID:	117433   Click image for larger version
ID:	117434   Click image for larger version
BIGBADJMY is offline   Reply With Quote
Old July 6th, 2014, 10:59 PM   #2
BIGBADJMY
BIGBADJMY's Avatar
Gona plate the shiny area first then box the arm to the knuckle. Got a old oven in the shop gona get the knuckle as hot as it will get before welding then put it back n oven and drop temp 50 degrees every half hour till its room temp. Then get to boxing in arm.
Old July 7th, 2014, 03:27 AM   #3
Wramblerguy
Wramblerguy's Avatar
Is it just me or is that not actually a flat top knuckle?
3rd generation jeeper
Old July 7th, 2014, 09:12 AM   #4
YellowYJ
YellowYJ's Avatar
Ball joint Dana 60?
YellowYJ is offline   Reply With Quote
Old July 7th, 2014, 02:06 PM   #5
BIGBADJMY
BIGBADJMY's Avatar
Yes its a bj 60 not very desireable but here is the pieces I made to plate the knuckle with so when iam welding the highsteer arm on iam welding steel to steel. In one pick of highsteer arm u can see it was a violent hit it actually bent the arm at the second bolt hole because its egg shaped now. Hopefully because iam boxing the arm completely in it wont be a problem. Well my internets is down so no pics till wed.
Old July 7th, 2014, 04:44 PM   #6
Wramblerguy
Originally Posted by YellowYJ View Post
Ball joint Dana 60?
Ahh ok bj 60
Sounds like a good plan, looks like it should hold up
Old July 7th, 2014, 05:22 PM   #7
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Looked like it should've held up before it hit the woods course to lol
Sent from my SGH-M919 using Tapatalk
Mihlfeldl2005 is offline   Reply With Quote
Old July 7th, 2014, 07:06 PM   #8
Wramblerguy
With just 2 bolts and not much of a flat surface to clamp against?
Old July 7th, 2014, 07:10 PM   #9
Mihlfeldl2005
Nah, fully gusseted to the stock arm. That's what it was like before it broke. The weld came completely out of the lower arm. Not like it cracked but it just pulled out, like pulling a plant out of the ground, it took the roots with it lol
Old July 7th, 2014, 07:12 PM   #10
chevotass
chevotass's Avatar
cast welding does that
Old July 7th, 2014, 07:12 PM   #11
Wramblerguy
Ahh ok
That is odd
Old July 7th, 2014, 10:52 PM   #12
BIGBADJMY
BIGBADJMY's Avatar
I got pics if nick will post them lol it will be bullet proof compared to what it was just waiting to see if this oven can get my part hotter then 350 by morning if not iam pullin it out in welding it any way.
Old July 7th, 2014, 11:08 PM   #13
BIGBADJMY
BIGBADJMY's Avatar
I think whoever welded it used the proper rod half the time but they definitely did not pre heat proper or post heat at all looking at the break closely. One weld had no penatration the second weld odviously on other side had alittle better but hopefully my weldin skills are good enough to make it never break that arm again. When iam done heading to the dunes to see some air;) n when I get back ill do the other knuckle when I get home.
Old July 7th, 2014, 11:21 PM   #14
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
You'll be further ahead if you designed up an additional bracket that eliminated the 'single shear' condition that you have now. The bracket would sandwich to the bottom bolt of the tie rod end and then offset down to the oprginal tie rod pick up point, thereby elminating the bending component you have with an unsupported joint.
For what it's worth I would NEVER weld that joint. A double shear condition will get you what your looking for.
jim-kb8ymf
kb8ymf is offline   Reply With Quote
Old July 8th, 2014, 04:31 PM   #15
BIGBADJMY
BIGBADJMY's Avatar
jim-kb8ymf
Ya I thought that as well. Basicly runing a long bolt threw both the high steer and original tierod hole but curent highsteer arms dont even come close n iam to impatient n cheap to buy new arms because id have to have them made. So I just thought id throw metal at it. Its cheaper n quicker my way n I bet it dosent break there again. I was going to try n box it all in then try to get double sheer out of the boxing process. Hard to explain but ill takes some pics n be able to upload weds or thurs.
Old July 11th, 2014, 01:35 AM   #16
BIGBADJMY
BIGBADJMY's Avatar
Well its done finally
ID:	117579   Click image for larger version
Old July 12th, 2014, 03:53 PM   #17
BIGBADJMY
BIGBADJMY's Avatar
Well heres a couple more
ID:	117622   Click image for larger version
Old July 12th, 2014, 04:15 PM   #18
BIGBADJMY
BIGBADJMY's Avatar
Heres dune ready
Name:	2014-07-12 17.10.23.jpg
Page generated in 0.33663 seconds with 78 queries
