What Stall Converter? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 6th, 2014, 10:09 PM   #1
chasetheface123
chasetheface123's Avatar
Default What Stall Converter?
I am trying to decide on a converter for my truck, and need a little advice on what Stall I should shoot for. The truck is a 91 F150 Truggy, 351w/C6. The truck weighs around 4k, and the motor is pretty much stock besides a set of headers, and running on propane. Currently the truck is on 40's, and will be running 5.13s/5.38's (Undecided). The truck will be used primarily for the trails/rocks, along with the occasional high speed run/bog. I was told around 2000-2200, but am completely clueless what seems right. Does this sound about right? Also, what's a decent brand/model that isn't hard on the pocket?
Thanks!
chasetheface123 is offline   Reply With Quote
Old July 6th, 2014, 10:16 PM   #2
I run a stock "Rv" converter in my buggy with 351-c6-5.38s-42s I like the low rpm stall for ease of low speed crawling.
Higher stalls also create more heat in the trans.
Old July 6th, 2014, 10:18 PM   #3
jhnyquest
goof ball
jhnyquest's Avatar
That's a decent stall.
Old July 6th, 2014, 10:21 PM   #4
1TFROT
1TFROT's Avatar
the stall in my th350 is around 2200. I personally think it's too low. it still wants to push through the brakes in low range. that and won't launch quite how I want( rig is 5300# with 42s and 5.38s) motor is a decently built 6.0 lq4
a good external trans cooler will take care of possible heat issues.
1TFROT is offline   Reply With Quote
Old July 6th, 2014, 10:27 PM   #5
What tcase, behind the c6....
If 205, it won't below enough stall to push through anything lol.
Old July 6th, 2014, 10:42 PM   #6
chasetheface123
Right now it is a 1356, but will be a 205 here very shortly. Just waiting on shifters
Old July 6th, 2014, 10:44 PM   #7
chasetheface123
I'm also running an external cooler.
Old July 6th, 2014, 10:53 PM   #8
yukonjake
yukonjake's Avatar
When I talked to my tranny guy about running a stall he told me to see what my cam recommended sure enough it said to run 22-2400 stall so if your stock I wouldn't go to big
yukonjake is offline   Reply With Quote
Old July 6th, 2014, 10:58 PM   #9
1TFROT
1TFROT's Avatar
and that is true as well. cam choice will make a diff
Old July 7th, 2014, 08:52 AM   #10
Bones
Bones's Avatar
I would not go over 2200. I put a 2000 in my race buggy (351W/C6/Atlas) and it was the best compromise of go-fast launches, crawling and heat management. It took a huge cooler to control it in race environments. This is what I ended up running; http://www.griffinrad.com/page6acc.php?key_id=CXU-00001
With this smaller cooler, I would be at 260F in 12 minutes with the 2000 stall converter. http://www.summitracing.com/parts/der-13900/overview/
Also, the brand and quality of the TC will have a big impact on the "feel" and heat control too. Not all 2000 stall converters are rated the same. For budget builds, I usually go with Hughes products. For other Ford specific trans stuff, I really like Broader Performance (especially valve bodies). http://www.broaderperformance.com/ The quality and function of the valve body also impacts heat, as I found out the hard way with ATI valve bodies.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 7th, 2014, 09:19 AM   #11
In the hughes lineup, their Tow Master converters usually work well for that type of application. As bones said, advertised stall speed is only one piece of the puzzle. Stall Torque Ratio and efficiency are not equal across different manufacturers converters that might all have the same stall ratio.
Old July 8th, 2014, 10:51 PM   #12
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Call up http://www.edgeracingconverters.com/
Only guy who knew what he was talking about when I was pricing out converters before trans swap. Everyone wanted to sell me off the shelf stuff.
Page generated in 0.31845 seconds with 59 queries
