gearing queation - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 5th, 2014, 12:16 PM   #1
hoyt5885
hoyt5885's Avatar
Default gearing queation
I have a 99 tj 4.0 3 speed auto with Dana 30 and 35 axles looking to change gearing looking for 4:56 or 4:88 what is everyone suggesting will be driven on and offroad
hoyt5885 is offline   Reply With Quote
Old July 5th, 2014, 12:32 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Tire size is a factor here.
Old July 5th, 2014, 12:36 PM   #3
Agreed on tire size.
Type of wheeling? Mud, sand, snow, rocks?
Lockers?
Suspension?
How much on road, how much off road?
Daily driver or trail rig that needs to see the occasional street?
Old July 5th, 2014, 12:49 PM   #4
hoyt5885
hoyt5885's Avatar
35 in tires snow sand and some street driving lockers in both axles
Old July 5th, 2014, 12:51 PM   #5
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Say goodbye to those axle shafts! Lol
Sent from my SGH-M919 using Tapatalk
Mihlfeldl2005 is offline   Reply With Quote
Old July 5th, 2014, 12:58 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
4.88 is what I would run
H.o.r.e
Old July 5th, 2014, 01:05 PM   #7
HVYRTFT
Reed my teef
HVYRTFT's Avatar
If you avoid serious wheel speed and sudden bursts of traction, those shafts will be ok.
Old July 5th, 2014, 02:13 PM   #8
I agree with both of these statements.
Old July 5th, 2014, 04:07 PM   #9
Mihlfeldl2005
Should get Scott to do the gear swap to!
Old July 5th, 2014, 06:33 PM   #10
cerial
Direct Drive FTW
cerial's Avatar
With that pos 999 your not going down the highway anyway with those gears. Get lower gearing using the transfer case. Do a 4 speed swap like thousands have done before when you have everything around to punch it out in a weekend. Then it will be somewhat streetable.
Otherwise plan on replacing the top end of that engine or the engine itself soon after you do a swap.
Been there done that.
Old July 6th, 2014, 07:34 PM   #11
joe_jeep
welfare wheeler
joe_jeep's Avatar
4.10 or 4.56 with a 3spd auto if u see highway use.
4.88 if you see little street use.
Old July 11th, 2014, 06:35 PM   #12
cerial
Direct Drive FTW
cerial's Avatar
Your current transmission is a 999 and current axle ratio is 3.73. Your engine is screaming a bit over 3,000 at 75mph.
Your current transmission ratios are
2.74
1.45
1.00
An aw-4 ratios are
2.804
1.531
1.00
0.753
If I take your ratio and plug in a aw4's overdrive ratio you end up being able to run a 4.95/1ish rear axle ratio without effecting your engine rpm at highway speed. You will obviously get better acceleration and a small amount of off road performance.
If you are happy with the "street" performance that you currently have you can leave the axle ratio alone and simply increase the low ratio in the transfer case. You will get a very respectable increase in power offroad over what you will by simply switching out the axle ratios for about the same or less cash.
Lets do some math.
With your stock 3.73 axle ratio, 3 speed, and a 4/1 low you get a 1.28/1 increase.
With a 4.88 axle ratio and 3 speed you are going to get a 1.15/1 over stock.
With a 4.88 axle ratio and 4 speed you are going to get 1.21/1 increase
With a 4.88 axle ratio, 4 speed, and a 4/1 low added at a later time you get a 2.49/1 ratio increase without affecting your highway rpm.
Page generated in 0.29043 seconds with 59 queries
