Dodge Dana 60 front into gm - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 4th, 2014, 03:04 PM   #1
davidkassie
davidkassie's Avatar
Default Dodge Dana 60 front into gm
I found a dodge Dana 60 front from a 77 pickup. Has the full time plates on the ends. How hard to swap into my k5? And the Dodge 60 rear as well. Thanks
davidkassie is offline   Reply With Quote
Old July 4th, 2014, 03:37 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Rear shouldn't be bad. Likely need to to move the spring perches. Here's the result from a quick search:
1) All Chevy D60s are kingpin knuckle, whereas early (79-93 ) Dodge are kingpin
2) All Chevy D60s are internal style lockout / drive flange bearing hubs, whereas early (79-89 ) Dodge are external
3) Dodge and Chevy outer kingpin knuckles are very similar, and either will bolt to the other axle, but they are not identical - tie-rod placement is different - the Dodge mounts the TRE about an inch and a half higher.
4) Chevy leaf spring pads are 3 inches wide and 32 inches apart (center-pin to center-pin), Dodge are 2.5 inches wide and 32.5 inches apart.
6) Chevy rotors are 1.5" thick, dodge rotors are 1.25" thick, but the calipers are identical.
Old July 4th, 2014, 04:01 PM   #3
davidkassie
Ok. Do think the front bolts up the same?
Old July 4th, 2014, 05:35 PM   #4
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
#4?
Old July 4th, 2014, 06:35 PM   #5
davidkassie
I can tweak the springs a little. Lol
Old July 4th, 2014, 09:40 PM   #6
davidkassie
Dang people. Lol. I need to know asap.. He is gonna sell them asap
Old July 5th, 2014, 07:57 AM   #7
davidkassie
Ttt
Old July 5th, 2014, 10:02 AM   #8
koochman450r
koochman450r's Avatar
If it's a good deal, buy them. If you can use them do it. If not sell them. I think with the spring pad being narrower you may have a problem with the u bolts placement. Flexing each spring out .25 inch shouldn't cause much issue though. Not ideal, but for a trail rig it could work.
you won this battle.
Old July 5th, 2014, 10:37 AM   #9
davidkassie
600 for the pair seems cheap enough to resell for a profit.. lol. If I can't use them.
Old July 5th, 2014, 10:37 AM   #10
davidkassie
Are k5 front springs 3 inches wide?
Old July 5th, 2014, 11:57 AM   #11
koochman450r
You have a k5. Measure them!
Old July 5th, 2014, 01:00 PM   #12
davidkassie
Lol.. If I wasn't sitting at the ball field all day I would. thanks for the advice though
Old July 12th, 2014, 05:12 PM   #13
gearedfather
the front bolts right in...did a lot of these back in the 80,s......the brake fittings were different..
gearedfather is offline   Reply With Quote
Old July 13th, 2014, 12:13 PM   #14
davidkassie
Thanks.. I wound up buying gm stuff.
Old July 13th, 2014, 09:08 PM   #15
michigan maniac
michigan maniac's Avatar
Is the dodge axles still available?
Old July 13th, 2014, 09:12 PM   #16
davidkassie
Idk.. I can check. They are in green bay
Page generated in 0.26136 seconds with 71 queries
