Front axle sealing with 3/8" different covers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 3rd, 2014, 05:22 PM   #1
big86inthestixx
big86inthestixx's Avatar
Default Front axle sealing with 3/8" different covers
So I currently have a Dana 60 front axle with a BTF diff cover. It's flat as flat, checked many times with a straight edge.
I can pull the cover, seal it with black/blue permatext, right stuff,and anerobic sealant. It stays sealed until the first descent hit to the diff cover then poof. ..leaking again, a whole diff will drain in about a week.
How does everyone else seal their junk? Would a actual gasket work better?
Thanks GL4x4...
Old July 3rd, 2014, 06:28 PM   #2
hamsmotorsports
hamsmotorsports's Avatar
I use grey international/ ford silicon comes in a caulk tube. Are you useing rtv and anaerobic sealer together? If so that may be your problem.
hamsmotorsports is offline   Reply With Quote
Old July 3rd, 2014, 06:45 PM   #3
big86inthestixx
Just tried those two...not at same time. I'll try the grey..thanks
Old July 3rd, 2014, 07:00 PM   #4
lgottler
lgottler's Avatar
Both mine are leaking as well. Not that bad, but it leaves a spot a good 3" diameter after a week. Im using the black rtv, stock covers. But yes, a good smack and they leak, never tried an actual seal...
lgottler is offline   Reply With Quote
Old July 3rd, 2014, 07:06 PM   #5
I use ultra grey permatex on everything.
Old July 3rd, 2014, 07:24 PM   #6
I use gaskets. They seem to do pretty good but I have to occasionally tighten the bolts.
Old July 3rd, 2014, 07:28 PM   #7
I use a gasket on front diff. Being the rear is custom shaved with a custom ruff stuff cover I use ultra grey. I think I went 3 yrs w/o removing the cover and it never leaked yes it was full of fluid lol.
Old July 3rd, 2014, 07:30 PM   #8
Wehan
Wehan's Avatar
I use gaskets with a skim coat of rtv black. Never had a leak and the covers require some heavy wrestling to get back off. Just make sure both surfaces are absolutely clean of all oil/dirt and junk or you'll end up with leaks no matter what you do.
Wehan is offline   Reply With Quote
Old July 7th, 2014, 09:44 PM   #9
big86inthestixx
Got a gasket, now to swap it out. After a few hard hits in sand lake, my front diff is now empty. ;)
Old July 7th, 2014, 09:50 PM   #10
joescamaro67
joescamaro67's Avatar
I found the cheap rtv seals better I think the expensive right stuff gets to hard. I switched to the cheap rtv and haven't had a leak since
joescamaro67 is offline   Reply With Quote
Old July 8th, 2014, 07:03 AM   #11
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I just use basic cheap black rtv....0 leaks on either cover even after repeated abuse. (Ruff stuff covers, hp 60 and sterling 10.25)
Old July 15th, 2014, 07:32 PM   #12
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
have you looked at the housing? I have seen where the housing have nicks.
4x4xdodgeman is offline   Reply With Quote
Old July 16th, 2014, 08:47 PM   #13
skife
skife's Avatar
http://lubelocker.com/
people rant and rave about how awesome these things are.
personally i use "the right stuff"
Old July 16th, 2014, 08:51 PM   #14
big86inthestixx
Been using the "right stuff" for years..no issues.
I pulled diff cover off, 5 lower bolts were bent bad enough that they barely wanted to thread out. Seems like the diff cover was shifted up.
So I think that's why it keeps breaking the permatext seal.
I bought a diff cover gasket for the front put all new bolts in.
Currently not leaking BUT I haven't smashed it into something yet.
If that ends up leaking, I'll try the Grey stuff cheapthrills suggested.
Thanks for all the suggestions I'll let you know if the gasket works.
Old July 16th, 2014, 10:01 PM   #15
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
What I've done in the past was to put whatever sealant... I use ultra black or ultra copper, in a nice bead all around the cover and bolt it on. Don't tighten the bolts up all the way. Let it sit over night or longer if possible then tighten bolts and fill with gear lube. The silicone cures in a thicker form and doesn't get squished out.
Cheap Thrills Off Road
Old July 16th, 2014, 10:07 PM   #16
xj4life
xj4life's Avatar
This
Old July 16th, 2014, 10:22 PM   #17
skife
skife's Avatar
Maybe time to tie your diff cover in with your axle truss?
Go big or go home, right?
Old July 16th, 2014, 11:19 PM   #18
Wramblerguy
Wramblerguy's Avatar
I have lube lockers and love them
Only time they have started to leak is when the bolts loosen up
3rd generation jeeper
Old July 18th, 2014, 10:40 AM   #19
mzy4v1
40's baby!
mzy4v1's Avatar
x2
I use these on both the front and rear D60's, never had a leak in 4 years. Pulled them probably 3 times to check and change oil and reuse with no issues.
mzy4v1 is offline   Reply With Quote
Page generated in 0.31389 seconds with 80 queries
