no bearing axle joints - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2014, 09:17 PM   #1
creeping death
I'm that guy.
creeping death's Avatar
Default no bearing axle joints
I pulled the axle joints off the jeep I just bought and not one of the eight caps had bearings.
They were a little sloppy but not that bad. I've never seen or heard of these joints that don't use bearings.
Anyone?
Old July 1st, 2014, 09:21 PM   #2
Bones
Bones's Avatar
plenty use bushings instead of bearings.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 1st, 2014, 09:24 PM   #3
Bullhed78
Bullhed78's Avatar
Yukon super joints?
Bullhed78 is offline   Reply With Quote
Old July 1st, 2014, 09:24 PM   #4
Grassman
2jz specialist
Grassman's Avatar
clicky
Old July 1st, 2014, 09:37 PM   #5
GREASYHANDS
GREASYHANDS's Avatar
Grease them often
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old July 1st, 2014, 09:58 PM   #6
creeping death
I'm that guy.
I pulled them because of the amount of play they had in them and replaced them with Spicer joints. I kept everything because I've never seen it before.
Old July 1st, 2014, 09:59 PM   #7
creeping death
I'm that guy.
Old July 1st, 2014, 10:20 PM   #8
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Pics reqired
Old July 1st, 2014, 11:52 PM   #9
jbsjunk
Little Member
jbsjunk's Avatar
You wouldn't believe it if you seen it.
Old July 2nd, 2014, 12:29 AM   #10
Wramblerguy
Wramblerguy's Avatar
I can get rid of that stuff for you if you want
No actually you can but new caps to rebuild them if they are Yukon super joints
3rd generation jeeper
Old July 2nd, 2014, 02:56 AM   #11
creeping death
I'm that guy.
They were also held in by snap rings, not C clips. I'll get some pix up after work today.
Old July 2nd, 2014, 06:29 AM   #12
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
should have left them in there and rebuilt chances are they are a much stronger joint. Also running full circle snap rings is the way to go
Old July 2nd, 2014, 07:58 AM   #13
creeping death
I'm that guy.
I still have them. after I figure out what they are, I am going to rebuild them if possible.
Old July 2nd, 2014, 08:29 AM   #14
creeping death
I'm that guy.
I have them soaking in the parts washer at work. I'll post some pics later
Old July 2nd, 2014, 08:32 AM   #15
Sounds like good joints that weren't maintained.
Old July 2nd, 2014, 08:38 AM   #16
Mr. Beefy
BFT!
Mr. Beefy's Avatar
http://www.fourwheeler.com/how-to/tr...t-super-joint/
Old July 2nd, 2014, 10:16 AM   #17
creeping death
I'm that guy.
Here's what I got....
Old July 2nd, 2014, 10:22 AM   #18
Lousypirate
Whoop Whoop
Lousypirate's Avatar
those are quite pitted... Looks like someone didn't grease them enough...
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old July 2nd, 2014, 10:48 AM   #19
They are not Yukons and yes, looks like someone let an expensive set of joints get ruined.
I would consider those scrap.
Old July 2nd, 2014, 03:10 PM   #20
creeping death
I'm that guy.
Didn't look that badly pitted before i cleaned them. Looks like I have cool new paper weights for the garage desk. :-/
Page generated in 0.39522 seconds with 83 queries
