Hi - lift jack - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2014, 04:57 PM   #1
Timmy
Timmy's Avatar
Default Hi - lift jack
My Hi - lift jack will not cycle down. It will cycle up though. Any suggestions?
Sent from my SPH-L720 using Tapatalk
Timmy is offline   Reply With Quote
Old July 1st, 2014, 05:05 PM   #2
Porscheguy
Porscheguy's Avatar
Turn it upside down....
Porscheguy is offline   Reply With Quote
Old July 1st, 2014, 06:59 PM   #3
bluminade
Bluminade Has Arrived
bluminade's Avatar
the top cross pin should be straight like the bottom one.
bluminade is offline   Reply With Quote
Old July 1st, 2014, 07:14 PM   #4
oil the piss out of it. Work the pins with a screwdriver. Wipe off the dirt and oil.... repeat about 3 times.
Should be good.
Old July 1st, 2014, 07:32 PM   #5
kickstand
circling the drain
kickstand's Avatar
Should be good.
this
Old July 1st, 2014, 08:51 PM   #6
srlbotanical
Because I Said So...
srlbotanical's Avatar
You also need to have weight on it in order to cycle down.
srlbotanical is offline   Reply With Quote
Old July 1st, 2014, 08:57 PM   #7
Timmy
Timmy's Avatar
Thanks.
Old July 1st, 2014, 09:02 PM   #8
Timmy
Timmy's Avatar
I will get it oiled up and start working the pins.
Old July 11th, 2014, 10:46 AM   #9
Outdoors
Field Repairs
Outdoors's Avatar
I have found that when you start to encounter this problem it is best to take it apart and clean it. They are very simple to do, no rocket science involved. Don't just clean the pins, the bores are what tend to hold the junk that makes them stick.
Outdoors is offline   Reply With Quote
Old July 11th, 2014, 09:24 PM   #10
Gunsworth
Gunsworth's Avatar
Throw it in a dumpster. Fuck those jacks, only time it served me well was to span the doam of my jeep after an accident so the doors would fit again.
Old August 1st, 2014, 10:05 AM   #11
Timmy
Timmy's Avatar
Well, i took it apart last night. Cleaned everything and it still will not cycle down.
Old August 1st, 2014, 10:40 AM   #12
Andy456123
Guest
Throw it in a dumpster. .
this. Get a new one if you can't figure out how to make that one work safely.
Andy456123 is offline   Reply With Quote
Old August 1st, 2014, 11:01 AM   #13
OveRover
OveRover's Avatar
I pee on mine before I use it, that works every time.
OveRover is offline   Reply With Quote
Old August 1st, 2014, 11:29 AM   #14
Bones
Bones's Avatar
they aren't rocket science. Look at it and find why the pins aren't moving properly. Guessing a burr on a pin or cam or hole.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 1st, 2014, 12:28 PM   #15
BlooMule
Old School
BlooMule's Avatar
Is that a real hi-lift or a harbor freight hi-lift?
-rw-rw-rw
Old August 1st, 2014, 01:43 PM   #16
Mine used to stick, needed to be tapped a few times lightly with a hammer to help the pin pop out of the bore.
I really dislike those things, and have done better in most situations with a good bottle jack and base. But there are a few scenarios they are useful (broken suspension parts).
Old August 1st, 2014, 02:36 PM   #17
kickstand
circling the drain
kickstand's Avatar
If cleaning it did not work, try banging on it.
Old August 2nd, 2014, 10:13 AM   #18
bbaXJ
Yooper In Training
bbaXJ's Avatar
Yes, cleaning, tapping, and oiling will generally do the trick. Both pins should be cycling in and out at different points in the stroke. If one isn't then there is your problem, you just need to determine why it isn't moving.
Those things are an absolute death trap but they can be very useful at times, though my use rarely involves lifting a vehicle. Breaking tire beads is what mine gets used for the majority of the time. For an offroad jack it's tough to beat this: http://www.tractorsupply.com/en/stor...%3B-jack-stand
Old August 5th, 2014, 04:48 AM   #19
Wramblerguy
Wramblerguy's Avatar
http://www.tractorsupply.com/en/stor...d?cm_vc=-10005
buy one of these ^
3rd generation jeeper
Wramblerguy is online now   Reply With Quote
Old August 5th, 2014, 04:50 PM   #20
bbaXJ
Yooper In Training
bbaXJ's Avatar
Good idea, I wish someone would have suggested that already....
Page generated in 0.42000 seconds with 83 queries
