cant get tierod off pitmen arm - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2014, 10:09 PM   #1
hitman
Default cant get tierod off pitmen arm
I have been trying to get the tie rod off the pit men arm on my 1996 dodge ram but it's not moving.
Any ideas to get it off?
hitman is offline   Reply With Quote
Old June 29th, 2014, 10:12 PM   #2
xj4life
xj4life's Avatar
Pickle fork or the two hammer trick
Old June 29th, 2014, 10:20 PM   #3
big86inthestixx
big86inthestixx's Avatar
Make sure u give the pitman arm a few good wraps, with a hammer near the tie rod stud, it 'jolts' the two metals good enough most times I don't even Need a pickle fork, they just pop right out.
Old June 29th, 2014, 10:21 PM   #4
big86inthestixx
I think that's xjs 2 hammer trick. It works great.
Old June 29th, 2014, 10:23 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Bfh
H.o.r.e
Old July 13th, 2014, 10:33 PM   #6
ZACH 461
Diesel tech
ZACH 461's Avatar
when brains fail brute force prevails
ZACH 461 is offline   Reply With Quote
Old July 13th, 2014, 10:43 PM   #7
Nuggets
I fix stuff!
Nuggets's Avatar
I use an air hammer to vibrate the living shit out of the part. Sometimes I have to heat and beat and the last resort is a tie rod fork. If I'm discarding the tie rod I go for the fork a little sooner.
Old July 13th, 2014, 11:17 PM   #8
1TFROT
1TFROT's Avatar
this and maybe a slide hammer
1TFROT is offline   Reply With Quote
Old July 13th, 2014, 11:46 PM   #9
Strider
Strider's Avatar
Send a message via Skype™ to Strider
It helps a lot to have a buddy apply downward pressure with a long pry bar while you hit the side of the arm. It rarely takes more than a couple good hits. Leave the nut on a few threads so your buddy doesn't hurt one of you with a rapidly moving pry bar.
Strider is offline   Reply With Quote
Page generated in 0.27368 seconds with 50 queries
