What u-joints do we like for XJ D30's? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 29th, 2005, 12:33 PM   #1
PavementPounder
PavementPounder's Avatar
Default What u-joints do we like for XJ D30's?
I replaced the front u-joints on my CJ back before I went away and can't remember for the life of me what brand they were or whether they were greaseable or non-greaseable. Its buried in the garage and I don't feel like getting all dirty trying to get to it right now.
I'm also shopping around for hubs, although I'm not sure they really need to be replaced just yet. The u-joints are worn, so I figure as long as I have the shit all apart, I will put new hub and rotors on since this is a used vehicle and everything is unknown. I plan to go with the slotted and crossdrilled rotors and Hawk pads that have been great on my Ram.
Old December 29th, 2005, 12:54 PM   #2
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Spicer or Napa's Brute Force.
cornfed is online now   Reply With Quote
Old December 29th, 2005, 01:22 PM   #3
Tonka
Tonka's Avatar
spicer
Old December 29th, 2005, 01:25 PM   #4
PavementPounder
Ah yes, Brute Force was what I used on the CJ and I believe they were non-greaseable. I'll check out the Spicers.
Old December 29th, 2005, 02:01 PM   #5
xjjeepthing
XJ Slut
xjjeepthing's Avatar
Send a message via Yahoo to xjjeepthing
Napa axle joints for your 98 XJ
378 without Antilock
377 with Anti
377 in Spicer is 52971x
378 in spicer is 52601x
Hope that helps
xjjeepthing is offline   Reply With Quote
Old December 29th, 2005, 10:03 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Brute Force are stronger but not greasable. I run the Brute Force and then just change them when they wear out. I have had less breakage with Brute force.
Old December 29th, 2005, 10:08 PM   #7
shawn
Resident HVAC/R Jambi
shawn's Avatar
Brute Force ROCKS!!
Old December 29th, 2005, 11:50 PM   #8
PavementPounder
If this was for a driveshaft, I would agree on just changing them. Ripping all the hub crap off is a pain in the ass and I won't be going through them that quickly in this vehicle. Thanks for the part # conversions!
Old December 30th, 2005, 08:57 AM   #9
xjjeepthing
XJ Slut
No problem glad i could help ,its my job(NAPA)
Old December 30th, 2005, 09:24 AM   #10
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i would use a spicer joint
i used to buy brute force all the time but when compairing the ujoints on my buggy you can tell a big difference between a spicer and a brute force, i have since changed all my joint to spicers except one.
not sure on a smaller joint there is alot of difference all mine are either 60 joints or 1410
Old December 30th, 2005, 12:13 PM   #11
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
What year XJ?
If it's older and non-ABS (smaller 260x joints) swap in some TJ shafts (or ABS shafts) and upgrade to 297's.
I usually use Brute Force in driveshafts because they die anyway... but for axle shafts use Spicer or Precision (from napa)
JcrOffroad
Zoom Zoom!
Old December 30th, 2005, 04:21 PM   #12
PavementPounder
Its a 98. I saw the size difference in the book at NAPA today regarding the ABS/non-ABS shafts. I have an ABS light on my dash, but I have never seen it light up or the system test itself upon start-up, so I'm sure I have the smaller joints. Looks like ABS became standard equipment in 99, as 99-01 are all the 1 3/16 OD joints. If I can find a set of TJ or ABS shafts quick enough, I'd consider it. The wheel hubs were in stock, and the rotors are coming tomorrow. Still have to order my brake pads. The TJ D30 is essentially the same housing? Same diameter shafts/bearings and same shaft length, etc but a bigger joint?
I was going to use the BF in the driveshaft at the axle. The guy at NAPA said he was very disappointed in the whole change from Spicer to Precision. Who carries Spicer? He couldn't tell me of anyone in the area (around Highland) except for Clyde's Frame and Wheel on Dixie Hwy.
Old December 30th, 2005, 05:28 PM   #13
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Weller auto carries spicer u-joints. A quick way to see if you have ABS is to look for an ABS pump on the driver fender.
You may have the larger u-joints even though you don't have ABS... I know Jeep started making them standard in the YJ after 95.
JcrOffroad
Zoom Zoom!
Old December 30th, 2005, 07:42 PM   #14
PavementPounder
Bah! Maybe I'll just hunt down the shafts so there's no guesswork.
Old December 31st, 2005, 09:09 AM   #15
silverxj
Recovering XJ owner
silverxj's Avatar
Spicers... I run the same ones that are in the D44 from a Rubicon.
Old December 31st, 2005, 02:08 PM   #16
PavementPounder
Yes, but where do you get them in Oakland County?
Old December 31st, 2005, 02:10 PM   #17
Mclovin
"The Situation"
Mclovin's Avatar
i got brute force driveshaft u joints one time that were greaseable and they have held up to my abuse very well.. but axleshaft u joints i know are very different from D-shaft ones..
Old January 20th, 2006, 07:32 AM   #18
PavementPounder
I went to Clyde's Frame & Wheel in Pontiac yesterday in search of Spicer axle joints, which they had in stock. There are indeed two different size joints listed for the XJ D30. The size difference does not appear to be in the joint, but in the bearing cap diameter - there may be two different sets of shafts out there. They had to get out the caliper to determine which one I needed.
Next time I'm at the dealer, I'll look up ABS and non-ABS shaft part #'s.
Old January 20th, 2006, 12:55 PM   #19
GMCsonoma94
1 wheel peel
GMCsonoma94's Avatar
Send a message via AIM to GMCsonoma94
i use the brute force ones alot but i was mad when they took the warrenty away. spicers are always hard to find it seems.
GMCsonoma94 is offline   Reply With Quote
Old January 31st, 2006, 10:52 PM   #20
Kawierider
Kawierider's Avatar
If you looking for the larger shafts check out a place in dearborn called dearborn axle or something like that. I can find you the name of the place if your interested.
basically they will give you a rebuilt shaft for 60 bucks and your core. Make sure you tell the guy which one you want, he will tell you there's no difference, and thier isn't to a normal person. The difference in the shafts is that the earlier, smaller ones have a pressed on knuckle, the stronger ones are a single peice, and have the correct number from a bove on them.
If that is incorrect then I have the beefy U-joint in the weak shaft....doh lol
Page generated in 0.33953 seconds with 83 queries
