Capreol Days Rock Crawl and Race - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Trail Rides & 4x4 Events
Old June 24th, 2014, 06:15 PM   #1
nickel4x4
Default Capreol Days Rock Crawl and Race
Saturday August 2nd is Rock Crawl, tech and registration starts at 9am and the fun begins at noon!
Sunday August 3rd is Rock Racing! depending on number of racers it will either be 3 hot laps, one car at a time or 5 hot laps. Fastest time's win!
We have been busy working and improving the courses and will be continuing to build on it over the next month. I'll post some pics soon.
See ya there!
Capreol is in Sudbury On. 3 hour drive east of SSM.
Sam
nickel4x4 is offline   Reply With Quote
Old June 24th, 2014, 06:18 PM   #2
nickel4x4
Stock class, Modified class and unlimited class
Truck requirements;
Stock Class:
All OEM Frame
OEM wheel base
OEM style suspension with a bolt on lift kit. If it came from the factory with leafs, it has to keep leafs. A TJ with a long arm kit is allowed the rear wishbone style upper control arm but no custom suspensions or modified lift kits.
Vehicles with removeable tops are required to have a roll bar.OEM Jeep cages are acceptable
Vehicles must be plated and insured.
Must have full doors on and a hard top.Vehicles with removable hard tops can skin the roof area with tin or alluminum minimum of 16ga thick.
OEM seat belts minimal.
No axle swaps.
No engine swaps
No under drives or doublers.
No Transfer case swaps such as an atlas, STAK or rubicon case into a TJ.
No sticky tires, No cut tires or siping
Tire sizes up to 36" only.
No hydraulic assist or full hydro steering.
Gas tank must be in stock location.
DOT Helmets must be worn by both driver and co driver.
All vehicle components containing fluid or oil must be free of leaks
A min. of one 2 1/2 lb fire extinguishers, one within reach of driver or co-driver
First Aid Kit
Stock Modified:
6" wheel base stretch maximum
Suspension changes allowed, leaf to 4 link, custom suspension, coil overs and air shocks allowed
Roll bar manditory
Axle swaps allowed
Under drives, doublers and after market transfer cases allowed.
engine swaps allowed
No sticky tires, no cut tires. Siping is allowed as long as the sipes are no more than 1/4" in width and no more than 2 per lug. I.E. a V or X shape sipes on a TSL is allowed.
Tire size up to 40" only.
Hydraulic assist and full hydro systems allowed.
Gas tank can be relocated. must be strapped into place and protected from possible driveshaft breach If it is inside the passenger compartment a fire wall is required around it. This fire wall must be made of sheet metal. The fire wall must be secured in place adequately as not to allow it to move away from the fuel tank during a rollover and must use a shut off valve accessible from either side of the vehicle.
First Aid Kit
Unlimited Class:
Any chassis modifications or custom built allowed (buggy's, truggy's or jeep buggy's)
Full cage around the entire drivers compartment including at least one door bar at least waist high, cross bar along the wind shield area top and bottom and behind the driver and passengers seats top, center and bottom (an X is acceptable behind the seat.)
Door panels are a must
Window nets are mandatory
Roof panel is mandatory.
5 point harness mandatory
Any Drive train allowed (engine, tranny, transfer case, under drives, axles)
Any style suspension.
Any size tires, sticky, cut and siped allowed.
Vehicles not equipped with a stock steering column with a functioning ignition switch must have a "deadman" switch installed that will remove all power to the engine and fuel system - it must be easily accessible to either occupant or support staff.
DOT Helmets for driver and co driver mandatory.
Fire Suits for Driver & Co-Driver, are mandatory
First Aid Kit
EVERYONE WILL BE FIT INTO A CLASS!!! there was a few concerns last year about not making tech and driving all that way for nothing, NO ONE will be turned away, all who come WILL definately get to participate!!!!
Hope to see you guys out here. PM or post up for any additional details needed.
Sam
Old June 24th, 2014, 06:54 PM   #3
jhnyquest
goof ball
jhnyquest's Avatar
Any pics of course?
Old June 24th, 2014, 07:21 PM   #4
nickel4x4
Old July 5th, 2014, 12:36 PM   #5
nickel4x4
I know it is still a little early yet, but I would like to know who is planning to compete this year as 4Wheel parts is going to donate a gift pack to all competitors.
I need to know who is in as early as possible to let them know how many we need!
Thanks,
Sam
Old July 6th, 2014, 11:02 AM   #6
NightKrawler
KOH Jackhammer
NightKrawler's Avatar
What is a Capreol? And where is this event taking place?
Subscribe for more videos http://www.youtube.com/user/bult4mud/videos
http://www.youtube.com/channel/UCYL4kHv0JB5sOKlPALLHGTQ
--l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_) .......
NightKrawler is offline   Reply With Quote
Old July 6th, 2014, 11:04 AM   #7
jhnyquest
goof ball
jhnyquest's Avatar
How much rebar is sticking out of the concrete?
Old July 6th, 2014, 04:51 PM   #8
bluminade
Bluminade Has Arrived
bluminade's Avatar
interested to know also?
bluminade is offline   Reply With Quote
Old July 6th, 2014, 04:55 PM   #9
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Capreol is just outside of Sudbury Ontario. About 3 hours from the border/bridge at Sault Ste. Marie.
Sent from Samsung Galaxy S4
Old July 7th, 2014, 01:00 PM   #10
nickel4x4
Like Mr Beefy said, we are in the Sudbury On. area.
There is no rebar sticking out of anything.
Sam
Old July 7th, 2014, 02:48 PM   #11
NightKrawler
KOH Jackhammer
Sam
Thanks for the update. Might want to add that to the original post
--l ,[____],
l---L 0lllllll0-
Old July 12th, 2014, 09:17 AM   #12
nickel4x4
Edited!
Is anyone planning on coming to this?
Thanks,
Sam
Old July 22nd, 2014, 09:36 PM   #13
nickel4x4
This year we are going to run 2 stages each on different courses in each class. The two leaders in each class will than run a shoot out on a new stage of gates to determine an overall winner.
Each class entry is $50, all cash going to the winners along with additional prizes.
Again , proceeds will be going to help cancer patients who need to travel for treatment . We have pulled together a lot of publicity to this event to benefit those in need as well as our sport, so lets put on a good show!
The class requirements are a little strict looking but they are outlined by the insurance provider, however we are quite lenient on many things and place competitors in classes best suited to be competitive, and no one is going to be turned away due to small details on tech inspection.
Thanks for looking!
Sam
Old July 23rd, 2014, 11:08 PM   #14
nickel4x4
https://www.youtube.com/watch?v=pjo5hmdSVSk
Old July 25th, 2014, 09:30 PM   #15
nickel4x4
I would rather win against another buggy than by default!!
Ill even put sone 33" ATs on it to give yas a chance....
Old July 30th, 2014, 08:51 PM   #16
nickel4x4
2 days till happy fun times!
Who's in?
Old July 31st, 2014, 12:43 AM   #17
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Who is driving that buggy in that video?
Old July 31st, 2014, 07:37 PM   #18
nickel4x4
His name is Karl. Hes from southern ontario.
I think hes coming out with a few others from that area.
Anyone on here entering?
Free camping with porta potty along the river, there will be games and activities for kids at the crawl as well as all around Capreol during the Capreol days festival.
Again, its a charitable event for Canadian Cancer Society so lets put on a good event and keep people coming back each year in support of a great cause!
Page generated in 0.43359 seconds with 77 queries
