yota housing crack - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2014, 08:19 PM   #1
stuftmunky2k
stuftmunky2k's Avatar
Default yota housing crack
came back from a wheeling trip noticed rear 3rd was leaking a lil bit on trailer. thought no big deal thing always shows a drop or to. parked buggy in the shop went out of town came back to all the diff fluid on the ground. thought i pulled the lower studs out again till i crawled under it and saw the crack. I don't remember hitting anything or feel anything hit the housing. didn't know if any one has seen this before or if its common on the yotas. just gonna fire up the tig welder and fix it just wanted some input or other peoples experiences
stuftmunky2k is offline   Reply With Quote
Old June 24th, 2014, 06:51 AM   #2
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
It's not surprising....the housings are not exactly stout. My fear with welding it would become this: Is it going to just continue to crack right where the weld stops next trip out?
Old June 24th, 2014, 07:12 AM   #3
stuftmunky2k
Ya i was thinking grinding the crack out weld it then plate the bottom with some 11gauge steel to try and help it. Makes me wonder if i need to go to a fabricated housing?
Old June 24th, 2014, 07:29 AM   #4
I would think the typical crack repair methods plus plating should be fine.
Drill out each end of the crack, grind out all the crack between the drill holes, weld it up. Then plating the bottom for strength.
Old June 24th, 2014, 08:06 AM   #5
stuftmunky2k
Think ive had this rear end apart more times than i can count. Build it break it repeat
Page generated in 0.15073 seconds with 38 queries
