Hydraulic cylinder size - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 21st, 2014, 08:22 PM   #1
big86inthestixx
big86inthestixx's Avatar
Default Hydraulic cylinder size
So, have a question maybe a more hydraulically smart person could help me with.
Say a hydraulic steering system has a 2x8" ram in it now, it works fine, over long periods of wheeling the fluid gets hot.
Would increasing the bore size, say to a 2.5/3"x8" lower fluid Temps because of more volume in the entire system, and/or stay cooler because the cylinder pressure doesn't need of be as high to do the same work?
Also wondering if it would slow my steering down?
Thanks for the thoughts/help.
sended frum dis stoopid fone
Old June 21st, 2014, 08:43 PM   #2
FyrFyr
FyrFyr's Avatar
It would slow your steering down because of the increased volume required per inch of travel. I do not think the increase in volume would make much difference in cooling. Going to a larger reservoir would probably help more. How about line sizing to the reservoir?
FyrFyr is offline   Reply With Quote
Old June 21st, 2014, 08:45 PM   #3
big86inthestixx
Reservoir has 3/4" line going from it to the pump. No reservoir on the pump, just the can around it.
Old June 21st, 2014, 08:52 PM   #4
Leave the cylinder size alone & add a better cooler and possibly a bigger reservoir.
Old June 21st, 2014, 08:53 PM   #5
big86inthestixx
I'll giver a whirl. :)
Thanks guys..
Old June 21st, 2014, 08:57 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Get a cooler with a electric fan combo and never look back. The derail coolers are really nice
H.o.r.e
Page generated in 0.26198 seconds with 41 queries
