Degree shims in the front - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 19th, 2014, 05:17 PM   #1
Wramblerguy
Wramblerguy's Avatar
Default Degree shims in the front
So a while ago I installed longer shackles on my jeep
Not super long but long enough to remove enough caster to have a negative effect in driveability
I know "they" say you aren't supposed to use degree shims on the front axle but why?
Has anyone done it and had any negative effects?
3rd generation jeeper
Old June 20th, 2014, 12:09 AM   #2
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I personally would get shorter shackles and use springs to lift it.
Old June 20th, 2014, 12:24 AM   #3
Wramblerguy
I would too but I've already got 4inch springs and I don't want to stretch it with waggy springs or go spring over
I'm just looking for anybody with any solid reasons I shouldn't use the in the front
Old June 20th, 2014, 06:37 AM   #4
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
why not use degree shims in the front? new lift spring come with them. its block not to use in the front.
4x4xdodgeman is offline   Reply With Quote
Old June 20th, 2014, 02:25 PM   #5
Wramblerguy
A degree shim is just a mini angled block
Old June 20th, 2014, 03:09 PM   #6
Andy456123
Guest
just rotate the inner C's!
Andy456123 is offline   Reply With Quote
Old June 20th, 2014, 03:16 PM   #7
Wramblerguy
I'll pass on that one lol
Old June 20th, 2014, 03:17 PM   #8
Wramblerguy
nobody has any real work reasons not to?
Old June 20th, 2014, 03:37 PM   #9
jbsjunk
Little Member
jbsjunk's Avatar
1 - New center pins
2 - New U bolts
3 - Shims 4'
4 - Install
Profit.
I see nothing wrong with doing this.
Old June 20th, 2014, 05:05 PM   #10
Wramblerguy
Originally Posted by jbsjunk View Post
1 - New center pins
2 - New U bolts
3 - Shims 4'
4 - Install
Profit.
Well unbolted aren't a year old yet
Might need longer center pins
But that's my plan since nobody can give me a reason not to
Old June 20th, 2014, 05:15 PM   #11
jbsjunk
Little Member
jbsjunk's Avatar
The wedge will be part of the spring pack. Not a big deal. I've done a few of them. Do it and enjoy. It'll drive nicer too, just make sure you put them in the right way. Put them in wrong and it'll drive worse. Fat end to the front.
Old June 20th, 2014, 05:55 PM   #12
Wramblerguy
Right
Jeep drove awesome with stock length shackles the tires just rubbed a lot
Thanks
Old June 20th, 2014, 05:58 PM   #13
jbsjunk
Little Member
jbsjunk's Avatar
And get the shims that the center pin goes thru, not around the head.
Old June 20th, 2014, 07:05 PM   #14
Wramblerguy
Probably gonna get http://m.quadratec.com/products/prod...d=16311+512X+A
Old June 20th, 2014, 07:18 PM   #15
Nvrenuf
Nvrenuf's Avatar
So let's see if I understand this. You put longer shackles on which gave a little lift and now your going to put a block that will lower lift? The shackle gave 1/2 the additional length because it is only lifting one side. The shim will lower spring pack by total thickness as it is in the center.
How much do you gain?
Old June 20th, 2014, 08:03 PM   #16
Wramblerguy
Shackles are probably 2" longer so that's 1" of lift
The degree shim isn't going to lower that much, more rotate
Old June 20th, 2014, 08:52 PM   #17
jbsjunk
Little Member
jbsjunk's Avatar
Originally Posted by Wramblerguy View Post
These should be dandy.
So, he'll lose 1/4" of height with the shim? See Jenny Craig.
Old June 20th, 2014, 10:14 PM   #18
RioGrande
RioGrande
RioGrande's Avatar
Product description says "can be used on FRONT or back"
If they were cast, I'd say No. I had a pair of cast shims break and partially fall out on the rear of my YJ.
RioGrande is online now   Reply With Quote
Old June 20th, 2014, 11:18 PM   #19
Wramblerguy
Ya the aluminum ones are cheaper....but this gets driven in the winter occasionally so I don't see that as a good idea
Not over $15-$20
Old June 23rd, 2014, 11:25 AM   #20
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Only way I would do it is if they were made of steel. Then weld them to the spring perch.
Guy who runs silver lake with me had aluminum shims in front, they broke on the sand and he had to use his winch to keep axle in place back to camp.
Page generated in 0.29885 seconds with 83 queries
