trans choice for buggy??? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2014, 02:52 PM   #21
Grassman
2jz specialist
Grassman's Avatar
if i know him, it will be beat on for sure. hes not very nice to gasoline powered anything lol
and budget is always a concern, for building and maint/rebuilding
Old June 18th, 2014, 02:57 PM   #22
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Seems like TH-400/NP205 would be a solid setup.
Old June 18th, 2014, 03:05 PM   #23
Grassman
2jz specialist
Grassman's Avatar
he was spouting off about an atlas too
so sounds like 4l60 with the stock case that he has, or 400 with an atlas...
Old June 18th, 2014, 03:09 PM   #24
Why atlas if you go T400? 205 will bolt up to the T400
Old June 18th, 2014, 03:20 PM   #25
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I'd assume gear ratios
Old June 18th, 2014, 04:14 PM   #26
Grassman
2jz specialist
Grassman's Avatar
cause hes a baller and does baller shit
Old June 18th, 2014, 05:08 PM   #27
big86inthestixx
big86inthestixx's Avatar
All these stories! If your buddy was a baller he'd a just went and got a built 4l80e AND a HERO case...
Pshh..amateurs..;)
sended frum dis stoopid fone
Old June 19th, 2014, 08:19 AM   #28
Tom
Because racecar
Tom's Avatar
Pshh..amateurs..;)
this
If you are going to run the 4l60E REPLACE:
Both sprags with new HD Borg Warners
Install hardened sunshell or beast sunshell. I recommended the later model one that uses a different forward hub and a torrington bearing.
Replace plastic accumulator pistons with aluminum ones
Install corvette servo
install shift kit (transgo orange box at minimum)
The transgo 4l60E-3 will give you the option of full manual control with no computer needed.
With the trans open, take a good look at the 3-4 clutches.
Old June 19th, 2014, 08:40 PM   #29
cerial
Direct Drive FTW
cerial's Avatar
The 400 all the way.
But, you should start off with the right 400.
Find one sitting behind a Buick or a Cadillac from the late 60's. These are easy to spot with there longer tailshaft and BOP bellhousing. Adapters to bolt these "stronger" transmissions to your drive train are easy to find without adding much length. The one that came with my 67 472 handled almost 500lbs in stock form. The same transmission can handle close to 600lbs before you start getting things hot. Working ones can be had for around $100 and are very easy to find if you know where to look.
As a side note if you dig deep enough you may be able to find a mid/late 60's switch pitch torque converter BOP 400. Basically, you have a 2000 low stall and when you nail it the angles change and you have a 3000 or so stall. They are great for launching a 5000lb car. These are usually distinctive by the linkage that going to the carb or the additional wire towards the side of the trans. Pull the pan and look for the extra wire if your in doubt.
Another one to look out for is a 425. This has a 1st with a spur gear instead of a helical. They are stupid tough and most can be found in RV's, buses, 1.5+ ton grain style trucks, etc. The sound of the spur gear is a cool factor in itself. These are getting harder to find so you may want to improve the platform (3rd) once you have one.
cerial is online now   Reply With Quote
Old June 20th, 2014, 11:29 AM   #30
those are TH475s, not 425s..
Old June 20th, 2014, 11:42 AM   #31
Those things are big, heavy, inefficient, and make a lot of heat in the high stall range. Good idea for its day, but not going to perform like a modern converter.
A nice aftermarket converter is going to help it, no matter what trans is selected. 5.3's aren't exactly low end torque monsters. The stock converters can be a real performance killer, especially the stock 4L80e piece.
I would think even a TH350 is a viable option, lighter and less parasitic. Maybe with 2.75:1 first gear installed.
I have a 700R4 going behind my built 6.0, mine is built by KillerB similar to the specs listed above for the 4:60e, with 5 gear planetary also. I hope it holds up, the 700R4 case was needed to interface with my t-case of choice.
Old June 20th, 2014, 12:34 PM   #32
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
^ Still going to run the brevada case?
RIP FULLSIZE4LIFE
Old June 20th, 2014, 12:39 PM   #33
Think so, yes. But its going into a 71 Jimmy, instead of my CJ6.
Old June 20th, 2014, 01:50 PM   #34
crunchedtj99
be a man build a powerglide!
crunchedtj99 is offline   Reply With Quote
Old June 20th, 2014, 01:53 PM   #35
frdboy
frdboy's Avatar
Originally Posted by crunchedtj99 View Post
be a man, put a NV4500 in it!
Fixed!
Old June 20th, 2014, 02:23 PM   #36
chevotass
chevotass's Avatar
goat
Old June 20th, 2014, 02:48 PM   #37
6L80e with tapshifting
Old June 20th, 2014, 02:49 PM   #38
big86inthestixx
this would be AWESOME!
Old June 20th, 2014, 02:56 PM   #39
jhnyquest
goof ball
jhnyquest's Avatar
700r4
Old June 20th, 2014, 03:50 PM   #40
Grassman
2jz specialist
Grassman's Avatar
isnt a 4l80 basicly an updated 700r4?
Page generated in 0.49963 seconds with 83 queries
