05 ford escape engine removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 16th, 2014, 08:35 PM   #1
mudrunner456
mudrunner456's Avatar
Default 05 ford escape engine removal
I picked up an 05 ford escape 3.0 fwd auto. It has a blown motor. From looking at it I think the engine will come out thru the top. Just curious if anyome has done this this way.
mudrunner456 is offline   Reply With Quote
Old June 16th, 2014, 08:45 PM   #2
grnd93
grnd93's Avatar
I'm guessing it's easier to drop the engine and transaxle as one unit from the bottom, but I really have no clue
grnd93 is offline   Reply With Quote
Old June 16th, 2014, 08:49 PM   #3
Toyfish
Toyfish's Avatar
i have never done one of these but either way u do it will be pretty close to the same amount of work. It takes a little more work to drop everything out the bottom but u dont have to waste half a day pulling all the accessories off the motor so it will fit out the top.
Old June 19th, 2014, 08:51 AM   #4
beertestr
Take it apart the way it was put together. The engine and trans are usually installed from under on a fwd or awd car.
Follow the logic and you can figure out how to take it back on.
Sent from my DROID RAZR using Tapatalk
beertestr is offline   Reply With Quote
Old June 26th, 2014, 06:21 AM   #5
larryl
just a jeep
larryl's Avatar
out the top
remove crank pully
front exhaust manifold
drop exhaust system
tight fit
larryl is offline   Reply With Quote
Page generated in 0.43860 seconds with 38 queries
