Brake / Turn signal lights - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 15th, 2014, 01:22 PM   #1
Default Brake / Turn signal lights
I lost all brake and turn signal lights (both front and back). All fuses look good.
Since the brakes are live (fuse block) all the time and the turn signals are key activated, the only place I think they are commonly linked are in the steering column, which is a PITA to access. 4-ways do not work either. All other electrics work including tail lights.
I don't really know when I lost them but I was at the dunes last week and put on a good 50 miles around Holland and Saugatuck and no one said anything to me. We just ran into town for ice cream and my buddy behind me told me they were out.
Any help is appreciated.
Old June 15th, 2014, 03:38 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
It sounds like the turn signal switch took a dive. What is it on?
Old June 15th, 2014, 04:28 PM   #3
Toyfish
Toyfish's Avatar
possibly a ground issue?
Toyfish is online now   Reply With Quote
Old June 15th, 2014, 04:31 PM   #4
Tom
Because racecar
Tom's Avatar
Shorted/ grounded brake switch?
Old June 15th, 2014, 07:35 PM   #5
YJ. sorry
where? 2 sources of power, 4 different lights. What ground?
No blown fuses. Wouldn't a shorted switch blow a fuse?
Same question on where?
Old June 15th, 2014, 07:44 PM   #6
Toyfish
Toyfish's Avatar
Power runs thru the hazard switch before feeding the brake light switch so I would look into the hazard switch or wiring in column the wiring diagram doesn't say where the tail light grounds r located
Sent from my XT907 using Tapatalk
Old June 15th, 2014, 07:46 PM   #7
That's what I was afraid of. Pulling a column apart is not fun.
Old June 15th, 2014, 07:52 PM   #8
bearlys2005
bearlys2005's Avatar
Check for function at the plug at the base of the column before taking everything apart. Get your test lightand see what's got power.
bearlys2005 is offline   Reply With Quote
Old June 15th, 2014, 07:53 PM   #9
Toyfish
Toyfish's Avatar
very good place to start
Old June 15th, 2014, 07:59 PM   #10
bearlys2005
Also you have two circuits, one for brake and one for turn. To have them all fail is odd. Jim you have wipers and washers in your column switch correct? If so are they working okay?
Old June 15th, 2014, 08:03 PM   #11
Yes, and I don't know. Spent the afternoon enjoying family. I'll dive into it tomorrow.
Link to schematic?
Old June 15th, 2014, 08:18 PM   #12
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
its in the column
Old June 15th, 2014, 08:35 PM   #13
Originally Posted by unclebeaner View Post
its in the column
Excellent help.
Old June 15th, 2014, 08:44 PM   #14
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Link to schematic?
Someone posted this the other day:
http://www.revbase.com/BBBMotor/Wd
Old June 15th, 2014, 08:58 PM   #15
Looks like it has to be the column switch. Is there a common problem/fix?
http://www.revbase.com/BBBMOTOR/Wd/DownloadPdf?id=56612
Old June 15th, 2014, 08:58 PM   #16
joe_jeep
welfare wheeler
joe_jeep's Avatar
On my old green tj i had the hazzard switch go bad from water intrusion.
lost brake lights, turn signals, and hazzards. Never blew a fuse.
your yj is different, might be totally off base. Just an idea.
Old June 16th, 2014, 09:00 AM   #17
I've never taken apart the guts of a steering column. Are there any specialized tools required? How did you know it was bad Joe?
Old June 16th, 2014, 09:29 AM   #18
Tab
Tab's Avatar
Is this on your new chrome column?
Old June 16th, 2014, 10:22 AM   #19
Stock YJ tilt column.
I don't have your bucks to put bling on my rig.
Old June 16th, 2014, 11:30 AM   #20
19602
Its not that bad, you need a steering wheel puller and a steering wheel lock ring retainer removal tool. all of it is rentable at autozone.
19602 is offline   Reply With Quote
Page generated in 0.50570 seconds with 83 queries
