2002 Jeep TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 12th, 2014, 09:18 AM   #1
Bossman63
Two Trackers 4x4 Member
Bossman63's Avatar
Default 2002 Jeep TJ
I purchased this Jeep from a member on here a couple years ago. Over the past couple years, I didn't do much but drive it. In April I decided to dump some cash into it and make it more of a capable rig.
Upgrades:
Dana 60 Currie Rock Jock rear axle, 5.38 gears and a Detroit locker
Dana 44 G2 front axle with chromemoly shafts, e-locker & 5.38 gears
Rubicon Express 5.5" extreme long arm lift
Genright EXT gas tank
Metal Cloak rock rails, rear corner guards & 6" flares
39" BFG Krawlers.
Just returned from Drummond Island and put this thing thru the "break in" period. Deep water holes & rock climbs on Turtle Ridge ... no issues.
70+ miles of trails over 3 days ... no problem. The stock 4.0 had enough power to get me up and over all obstacles. HOWEVER ... I will be doing an engine swap this winter. Thinking of going with a Ford 5.0 just to be different.
Here's a couple pics. Before when I bought it, and after the upgrades on DI
Name:	profile pic TJ.jpg
ID:	116935   Click image for larger version
ID:	116936   Click image for larger version
Two Trackers Four Wheel Drive Club Member
Bossman63 is offline   Reply With Quote
Old June 12th, 2014, 09:22 AM   #2
bbaXJ
Yooper In Training
bbaXJ's Avatar
Nice looking rig......definitely shouldn't have bothered with the D44 front though.
Old June 12th, 2014, 06:49 PM   #3
alboy79
Where's your loyalty lie?
alboy79's Avatar
x2
Way to tall though.
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Old June 18th, 2014, 10:22 AM   #4
Bossman63
Bossman63's Avatar
Al, it's sitting next to yours at Rich's and it's not much taller than yours on the rollers. You throw your 40's on there I think you will be taller!
Old June 21st, 2014, 08:20 AM   #5
alboy79
alboy79's Avatar
For the record i was speaking from "my opinion".
i had no intention of slamming you or starting a debate...
But since thats the way its heading...
Ill bring my 40s over and mount them on.
And ill leave out the motor/trans/tcase/driveshafts/fuel system/radiator/winch, all of which are currently not in it.
Old June 27th, 2014, 08:21 AM   #6
Bossman63
Bossman63's Avatar
I'm not taking your comment as a slam. I know it's tall, but it still fits (barely) in my home garage so it's a smidge shorter than 7' with the 39" tires on it.
Old August 18th, 2014, 03:04 PM   #7
Bossman63
Bossman63's Avatar
Pic of the TJ in action on Drummond Island. Turtle Ridge upper section and then down in the lower section ... very wet down there!
Name:	39 tires.jpg
ID:	119121   Click image for larger version
Page generated in 0.25760 seconds with 45 queries
