wanting to build a 400+ hp SBF on a "budget" - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 12th, 2014, 09:53 AM   #41
Bones
Bones's Avatar
If haven't purchased a trans yet, look into the 4r70w with a stand alone controller. Don't waste your time or money on a aod or aode.
what stand alone controller have you had luck with?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 12th, 2014, 01:51 PM   #42
s.hembree
s.hembree's Avatar
I can't speak for him, but I've used the baumann controller on three different projects and have nothing but good things to say. There's one in my falcon currently.
Old June 12th, 2014, 03:25 PM   #43
sandguy356
bronco built for fun
sandguy356's Avatar
How about a 393?
stroker crank, 351W rods with an off the shelf 302 piston? I had one with just some E7TE heads with port cleanup, made just over 325@ the rear tires, and a boat load of torque too.
Crank was under $350, refurbished my rods and bought a set of CHP pistons.
total I was into it about $2400 carb to pan
sandguy356 is offline   Reply With Quote
Old June 16th, 2014, 03:45 PM   #44
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Read this today... And thought of this thread...
http://www.carcraft.com/techarticles...40616_26075266
ReiKo is offline   Reply With Quote
Old September 9th, 2014, 05:57 PM   #45
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
So I figured out how to build a ls motor from this thread. I wanna know how to build a 351w with fuel injection.
ATOMIC_BADBOY is offline   Reply With Quote
Old September 9th, 2014, 06:54 PM   #46
frdboy
frdboy's Avatar
How much ya wanna spend?
500 HP Motor
Stock block
4.100 x 4.030 418 CI
10:1 compression
Trick flow CNC 205 heads, AFR 225's or some ported High ports
Custom Hyd. Roller cam, link bar lifters
1.75" headers
Super victor EFI intake, accufab 4150 TB
Holley HP EFI
Old September 16th, 2014, 03:36 AM   #47
cerial
Direct Drive FTW
cerial's Avatar
Just build a dang 466. You can make 400hp with a 460 without much work at all. Toss some gears in the truck in the mid 3's and you will not need overdrive.
Watch Craigslist. 460's come across there all the time. Like this one for instance;
http://madison.craigslist.org/pts/4669836516.html
Page generated in 0.21736 seconds with 44 queries
