wanting to build a 400+ hp SBF on a "budget" - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2014, 03:46 PM   #21
Cartman
Can't lose with 42s
Cartman's Avatar
I'm a chevy fan boy and AJ's smoking crack
Next time you find a complete LQ9 for $600 buy 4 of them
OP: What about getting one of the lethargic EFI 460s and slapping heads cam and intake on it? I hear they make power for cheap......
Cartman is offline   Reply With Quote
Old June 11th, 2014, 03:59 PM   #22
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
Originally Posted by ReiKo View Post
You forget flywheel... Torque Convertor... Bell housing to make the AOD work... Shifter... And if he didn't want to use the AOD... Now he needs a transmission... And drive shafts... List goes on and on and on...
The best bet for his situation is to stick to the SBF and transmission he has... $$$ for $$$ a Windsor will also beat the "All mighty LSx"...
dropping 2k into a 6.0 and 2k into a 351 isnt even close. The LS would out perform everytime and not to mention last longer. Maybe this case with the trans and what not, the 351 would be better. Id rather have a 4l80e or TH400 over a AOD any day. Just my opinon. I did like the 351W in my bronco though.
Yes, because people sell four at a time
Search Craigslist long enough and you will find a deal to.. I was finding 6.0s for 800 bucks all day when I was searching for them. Maybe the price shot up recently. Just have the find someone that doesn't think they are worth gold.
If you dont like it, get out.
AJ Hall is offline   Reply With Quote
Old June 11th, 2014, 05:59 PM   #23
Gunsworth
Gunsworth's Avatar
but everyone seems to think they need one with like 50k on it. I have beat the shit out of the 6.0 on my work truck pulling trailers and plowing snow 90% of its life. im nearing 200k and it still runs great and never been opened up. people that think 6.0s are too expensive also think they need one with low miles.
Old June 11th, 2014, 08:36 PM   #24
going back to the original intent, you are taking a 210hp engine and trying to get 400hp out of it.
Its hard without adding cubes, to add 200 HP to a truck friendly engine. But, the recipe is pretty standard. Heads, intake, cam, compression, and headers/exhaust. There are some better flowing heads out there the late explorer stuff. In a car application, could do ok but you'll probably be sacrificing low end that you'd want in a truck.
One of the car mags this month, I think car craft, did some cam tests using an explorer 302. They were getting mid 300s.
Do you want carburetor or fuel injection?
Old June 11th, 2014, 08:52 PM   #25
I'm in the middle of building an LS2, mine is around 90k and still has a great crosshatch on the walls. Heads are on the way back from advanced induction should be making a wee bit more than 400hp.
Old June 11th, 2014, 11:55 PM   #26
booblinker
Sore and Tired 24/7
booblinker's Avatar
6.0 LS Swap with a cam... will have a very reliable/high reving 400 hp motor with lots of potential for well under 2k.
This is an idea I have been throwing around
Not set on an AOD, just thought it would be the easiest to add OD to an old ford
Old June 12th, 2014, 06:42 AM   #27
If haven't purchased a trans yet, look into the 4r70w with a stand alone controller. Don't waste your time or money on a aod or aode.
Old June 12th, 2014, 07:58 AM   #28
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Go with a 4r70w like mentioned...
SBF Windsors are easy to make really good power... One trick they use to do back in the day to bump up compression was turn the piston 180 in the bore...
ReiKo is offline   Reply With Quote
Old June 12th, 2014, 07:58 AM   #29
ReiKo
ReiKo's Avatar
Originally Posted by haggar View Post
i'm in the middle of building an ls2, mine is around 90k and still has a great crosshatch on the walls. Heads are on the way back from advanced induction Should be making a wee bit more than 400hp.
317? 243?
Old June 12th, 2014, 08:00 AM   #30
Lousypirate
Whoop Whoop
Lousypirate's Avatar
wat? That doesn't make any sense.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old June 12th, 2014, 08:04 AM   #31
ReiKo
ReiKo's Avatar
They would take the piston and turn it 180 so the intake side of the piston was on the exhaust side and the exhaust side was on the intake side... Doing this with milling the head... Some of the old time street races in Detroit did this all the time...
Old June 12th, 2014, 08:06 AM   #32
Lousypirate
Whoop Whoop
That doesn't change the volume of the cylinder... how would that effect compression.
Milling the head changes compression.
Old June 12th, 2014, 08:06 AM   #33
ReiKo
ReiKo's Avatar
What it does is change the arc of the rod, and has the same effect as a slightly longer rod...
Old June 12th, 2014, 08:11 AM   #34
317? 243?
LS2 = 243, which is what I have. The LQ9 would be 319s. Same rotating assembly, but the LS2 is ~90 lbs lighter.
Mine are 243s, with AI's 226cc cnc program, milled down to 62cc chambers. Cam is 0.630/0.610.
Old June 12th, 2014, 08:11 AM   #35
kickstand
circling the drain
kickstand's Avatar
what we always did was flip the rod over, put the wristpin side on the crank and the crank side on the wrist pin, it doubled the compression and also allowed you to still run pump gas while allowing the motor to spin more RPM
Old June 12th, 2014, 08:13 AM   #36
ReiKo
ReiKo's Avatar
Wasn't sure if you were going NA or F/I
Old June 12th, 2014, 08:25 AM   #37
firehawk
Live Action!
firehawk's Avatar
If you go with a 4R70W getting one that is from a 1999 or newer will get you a better trans than the earlier ones, better internals.
Old June 12th, 2014, 08:27 AM   #38
Stock wrist pin is offset to reduce piston slap. Flipping them improves leverage on the piston when you aren't concerned with OE type NVH and longevity requirements.
Oops, Reiko got it first..
Old June 12th, 2014, 08:30 AM   #39
thought hard about it, but part of building the '71 is to have the sound of a high compression, tight LSA motor (street cruiser/hot rod thing).
Old June 12th, 2014, 08:43 AM   #40
ReiKo
ReiKo's Avatar
Can't deny that sound....
I'm a turbo guy myself... Just love the high pitch whine...
One day it will see the light of day...
Page generated in 0.51794 seconds with 83 queries
