wanting to build a 400+ hp SBF on a "budget" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2014, 11:56 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default wanting to build a 400+ hp SBF on a "budget"
Obviously I know It won't be cheap, it runs and drives now, and I am fine with it, but i am looking to build a 400+ hp 4k miles a year reliable truck. The plan is drive it as is, and build a motor and trans with a 2k budget a year over the next 2 years. So basically want to build a 400+ HP 351 windsor, and an AOD for about 4K, If need be I will go another year and add more $$ to the plan.
Old June 11th, 2014, 08:19 AM   #2
Bones
Bones's Avatar
fuel injected?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 11th, 2014, 08:28 AM   #3
kickstand
circling the drain
kickstand's Avatar
http://www.tristarengines.com/catalo...der-heads.html
All done.
Old June 11th, 2014, 08:47 AM   #4
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Make it Carb... New intake... Cam... Headers... There's multiple ways about going with this...
You can also bore out the motor and shove in a HC piston to run pump gas 93 only and watch it come to life...
ReiKo is offline   Reply With Quote
Old June 11th, 2014, 08:52 AM   #5
Lousypirate
Whoop Whoop
Lousypirate's Avatar
for an extra $200, you can get engraved on the valve covers.
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old June 11th, 2014, 12:10 PM   #6
BOGDOG
BOGDOG's Avatar
Ford SVT used to sell a crate engine that was about 400HP. My buddy spent $5K to duplicate it. I'm not sure if it is still available.
Old June 11th, 2014, 12:48 PM   #7
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
6.0 LS Swap with a cam... will have a very reliable/high reving 400 hp motor with lots of potential for well under 2k.
If you dont like it, get out.
AJ Hall is offline   Reply With Quote
Old June 11th, 2014, 01:21 PM   #8
Nowhere near under $2k. This makes a nice swap into Fox mustangs, tho.
Old June 11th, 2014, 01:39 PM   #9
Bones
Bones's Avatar
I will pay you $2K for a high revving 400hp 6.0L with a cam and everything required to swap into any vehicle.
you sound like a used car salesman
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old June 11th, 2014, 01:53 PM   #10
ReiKo
ReiKo's Avatar
Old June 11th, 2014, 02:02 PM   #11
Lousypirate
Whoop Whoop
yup, right up to the point you learn that healthy 6.0 you bought is only a 4.8
Mary Jane (46 CJ2a)
Old June 11th, 2014, 02:16 PM   #12
deerebowtie
Unchained
deerebowtie's Avatar
Would you have any interest in a 347 stroker than ran 10.50's in an 87 fox body @ Milan?
Old June 11th, 2014, 03:23 PM   #13
AJ Hall
Kickin' Up MUD
AJ Hall's Avatar
Really? Because the LQ9 in my truck now was 600 bucks and runs flawlessly.
Nice Cam= $400 (estimate new)
LS Carburated Intake= $350 (summit website)
Carburator= $500 (estimate new)
MSD Box to run factory coil setup= $400 (summit website)
Besides little misc shit.. that's $2,250.... thats with all new parts except for the motor.... there was a guy selling a 6.0 LQ9 already had a cam, intake, carb, and MSD box on Craigslist. Motor had 90k on it. He was asking 2500 for a month or so before dropping the price and then finally selling it.
Old June 11th, 2014, 03:44 PM   #14
Bones
Bones's Avatar
I'm not shoving a carb on a LS
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old June 11th, 2014, 03:47 PM   #15
ReiKo
ReiKo's Avatar
You forget flywheel... Torque Convertor... Bell housing to make the AOD work... Shifter... And if he didn't want to use the AOD... Now he needs a transmission... And drive shafts... List goes on and on and on...
The best bet for his situation is to stick to the SBF and transmission he has... $$$ for $$$ a Windsor will also beat the "All mighty LSx"...
Old June 11th, 2014, 03:48 PM   #16
ReiKo
ReiKo's Avatar
Why not? Just curious... Not trying to be a dick or start anything...
Old June 11th, 2014, 03:53 PM   #17
Bones
Bones's Avatar
fuel mileage, tuning, efficiency, i don't have a mullet, I'm not driving a carbed truck around 4K miles per year, The poster isn't asking about a drag car.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old June 11th, 2014, 03:53 PM   #18
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Because carbs bring the suck
H.o.r.e
Old June 11th, 2014, 03:58 PM   #19
ReiKo
ReiKo's Avatar
Never said you had a mullet... Seen plenty of street cars with LSx's in them with carbs... Each to his own...
Old June 11th, 2014, 04:01 PM   #20
Misc little shit adds up fast. If you are doing a cam swap of any value, then you also need springs & retainers, should do new pushrods, and really should do some of the gaskets, new crank bolt, new timing chain as a minimum. If you are getting a $600 motor, its probably got a lot of miles on it. I'd add lifters and lifter trays, oil pump to the list. You've got $1000 in parts there for the cam swap. Depending on the year of the motor, its recommended to go to the heaviery LS2 timing chain with the heavier valvesprings. More $$$.
They run fabulous with them, and an MSD box to control the coil packs. Not my thing, but carb guys love the setup.
Page generated in 0.42758 seconds with 83 queries
