Any trucks with 30" trac bar?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2014, 06:39 PM   #1
whoischriscates
BLOOD, SWEAT, and BEERS
whoischriscates's Avatar
Default Any trucks with 30" trac bar??
Trying I find out if there are any trucks that came with a trac bar 30" long? Give or take and inch or two. Any help would be appreciated thanks!!
whoischriscates is offline   Reply With Quote
Old June 6th, 2014, 10:20 AM   #2
whoischriscates
Anyone!?
Old June 6th, 2014, 10:25 AM   #3
Bones
Bones's Avatar
I have no idea what you are trying to do, but why not just buy one made, or buy a universal kit? Even if you find one the right length, chances are the bushing or bolt size will not be correct.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 6th, 2014, 10:45 AM   #4
koochman450r
koochman450r's Avatar
If you need one made I can make you one. I have 1.5 x .250 dom and 3/4 heims at home right now. Bones is spot on.
you won this battle.
Old June 8th, 2014, 12:31 PM   #5
whoischriscates
Gotta leaf sprung ranger with a Dana 44 was going to use pass side axle pivot bracket for Frame mount and make a bracket in top of U bolt plate for axle mount. Trying to as cheap as possible. Wanted to pull a trac bar from junkyard or craigslist and just adapt one side to fit in the axle pivot bracket. I think an early bronco trac bar will work for what I want to do.
Old June 8th, 2014, 12:34 PM   #6
koochman450r
Why are you gonna put a track bar on a leaf sprung axle? That's not needed at all. It actually hinders suspension movement.
Old June 8th, 2014, 12:45 PM   #7
jbsjunk
Little Member
jbsjunk's Avatar
It's factory on Jeep YJ and older Ford Super Duty trucks. Those are leaf fronts.
Old June 8th, 2014, 02:29 PM   #8
Wramblerguy
Wramblerguy's Avatar
It's helps on road performance
Hurts off-road performance
My jeep has no trac bars or sway bar and is fine
3rd generation jeeper
Old June 9th, 2014, 11:01 AM   #9
koochman450r
I know its factory but it is also unneeded. It forces the axle to try to move in different directions. The track bar forces the axle to move in a sideways arc while the leaf springs are trying to move straight up and down but slightly fore and aft depending on shackle locations. Causing binding and limits off road capabilities..
Page generated in 0.43228 seconds with 50 queries
