Dana 44 Ford up problem!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 4th, 2014, 08:39 AM   #1
4x4wrangler
EMTinator
Angry Dana 44 Ford up problem!!!
Bought a Ford Dana 44 hp from a guy on craigslist who knew nothing about the axles. I got em for a good price with a Ford 9 inch rear. Everything looked nice but had an open carrier in the 44 with 5.13 gears.
My problem began as I started to disassemble the hp44 I realized the passenger side is a Chevy knuckle with chromalloy shafts and Yukon super joints. I thought great, except I cannot remove the axle shaft since it is too big for the Chevy knuckle opening. Then I tried to remove the knuckle but it wont let the ball joint studs out far enough to pull out. The Yukon u joint won't press out far enough while in the knuckle to pull the caps off and remove it, as i was going to remove the shafts separately as it was the only option I can think of... someone played a sick joke on me and I am out of ideas....
Am I missing something?!!!
4x4wrangler is offline   Reply With Quote
Old June 4th, 2014, 08:39 AM   #2
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
a die grinder?
ckupq is offline   Reply With Quote
Old June 4th, 2014, 08:56 AM   #3
4x4wrangler
EMTinator
Oh thanks... lol. Trying to refrain from that!! The guy before last put them in somehow or another... I don't want to damage the u joint or shaft as that is very costly! But wouldn't be able to replace the knuckle without separating the u joint and shafts during reassembly if I cut the knuckle off. Which the knuckle has high steer and i would l like to save that!!
Old June 4th, 2014, 09:00 AM   #4
Lousypirate
Whoop Whoop
Lousypirate's Avatar
sometimes they are very close fit between the hole in the knuckle and the OD of the shaft... Clean any rust or paint off of them and try again, if you have calipers, measure them. Sometimes You need to just get them lined up just right.
Like you said, they got it together somehow.
OR
sell it on GL4x4 for cheap and make it someone elses problem.
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old June 4th, 2014, 09:09 AM   #5
Complete Off Road
Complete Off Road's Avatar
Getting Yukon Chromo's through the knuckle opening can be a pain sometimes. Most guys use the die grinder to put four notches in the opening of the knuckle to be able to get the shafts through. That way it is clearanced for future shafts as well.
Or you can grind down the outside of the axle yokes.
Complete Off Road is offline   Reply With Quote
Old June 4th, 2014, 09:58 AM   #6
Don't grind the axle yokes. Put a small clearance in the knuckle. It's fairly common.
Old June 4th, 2014, 10:33 AM   #7
joe_jeep
welfare wheeler
joe_jeep's Avatar
I had to clearance both. It comes out, and goes in. But only in one spot. Has to be lined up perfectly.
Old June 4th, 2014, 11:47 AM   #8
4x4wrangler
EMTinator
Great to know!! Ill have to check it later. I didn't necessarily try clocking it in any particular fashion. Thanks guys!
Old June 4th, 2014, 08:23 PM   #9
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
Didn't the yukon super joints have needle grease zerks in all the caps?
Old June 5th, 2014, 08:58 AM   #10
Complete Off Road
yes, there is a needle grease zerk on the top of each cap. You can install them after you slide the axle in if they are causing a clearance issue.
Old June 5th, 2014, 12:46 PM   #11
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Same here
Old June 5th, 2014, 06:00 PM   #12
4x4wrangler
EMTinator
Awesome!!! It worked out great guys! I had to grind only a little bit and they were free!!!
Old June 6th, 2014, 05:27 AM   #13
Glad it worked out.
Page generated in 0.35131 seconds with 62 queries
