Need help- Pontiac G6 rough idle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2014, 05:33 PM   #1
Jeep Thrills
Lumbermonkey/pedalpusher
Jeep Thrills's Avatar
Default Need help- Pontiac G6 rough idle
2.4L 145CI L4 FI. 106,000 miles. Just started running rough today. Rough idle and stalling. Converter has been replaced once over a year ago. Do they have an inline replaceable fuel filter or is it in the tank?
Jeep Thrills is offline   Reply With Quote
Old June 3rd, 2014, 05:38 PM   #2
Toyfish
Toyfish's Avatar
there is a inline filter on those have the spark plugs ever been done? is there a check engine light on?
Old June 3rd, 2014, 05:40 PM   #3
Jeep Thrills
CEL has been on for a while. It's the wife's car, so no idea how long. Plugs have never been done as far as I know.
Old June 3rd, 2014, 06:15 PM   #4
Toyfish
Toyfish's Avatar
change the plugs first only use ac delco platnim plugs
Old June 3rd, 2014, 06:30 PM   #5
Jeep Thrills
I'm guessing the electrodes should not be pointy. Sending the wife to get some right now. I guess I get to feed the skeeters some more.
Old June 3rd, 2014, 06:32 PM   #6
Toyfish
Toyfish's Avatar
they should have a small point on the tip they should be changed every 100k and its a easy place to start if its running shitty
Old June 3rd, 2014, 08:03 PM   #7
fordbronco
the ocean called
fordbronco's Avatar
X2 especially since it's the ecotec. Should take you 2 minutes to put the plugs in.
Old June 3rd, 2014, 08:13 PM   #8
Jeep Thrills
New plugs, same crap. The engine will rev if you pump the pedal to bring the rpms up, but when I let the rpms come down it stalls. I don't have a fuel pressure tester, but when I push the bleeder in after it stalls I just get a short burst of fuel, but it seems like there should be more. I might have to rent a pressure tester tomorrow.
Old June 3rd, 2014, 08:43 PM   #9
fordbronco
the ocean called
fordbronco's Avatar
While you're out there tomorrow, I'd check into the CEL and see what you have for codes.
Old June 3rd, 2014, 08:53 PM   #10
Jeep Thrills
I'd have to get it scanned somewhere or borrow a scanner. I found a recall notice for a defective pump connection, hoping it'll be that easy.
Old June 4th, 2014, 08:20 AM   #11
Outdoors
Field Repairs
Outdoors's Avatar
Check the line coming off the PCV valve. When the crack the create a problem close to what you are describing.
Outdoors is offline   Reply With Quote
Old June 4th, 2014, 08:23 AM   #12
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
Sounds like a TCC solenoid to me.
lepp1892 is offline   Reply With Quote
Old June 4th, 2014, 05:59 PM   #13
Jeep Thrills
Didn't get a tester, but I can get the engine to run off of carb cleaner, so I know it is fuel related.
Old June 5th, 2014, 07:55 AM   #14
Outdoors
Field Repairs
Outdoors's Avatar
Looks like Toyfish then had the answer in the first seven words of suggestions. Good job Toyfish! You put this old man to shame.
Old June 5th, 2014, 10:05 AM   #15
Toyfish
Toyfish's Avatar
Trust me its not easy being this good lol
Sent from my DROID X2 using Tapatalk 2
Old June 5th, 2014, 03:37 PM   #16
Jeep Thrills
fuel pressure regulator is
in the tank I'm guessing?
Old June 5th, 2014, 03:38 PM   #17
Jeep Thrills
Picking up a fuel pump on the way home.
Old June 7th, 2014, 07:29 PM   #18
Jeep Thrills
Fixxered. Miller time.
Page generated in 0.42475 seconds with 77 queries
