ceramic inside cylinder - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2014, 02:35 PM   #1
redram98
redram98's Avatar
Default ceramic inside cylinder
Chrysler 4.7 motor, ceramic on plug splintered inside cylinder. Does anyone have experience retracting the ceramic from a cylinder with out disassembly of the block? Thanks in advance.
redram98 is offline   Reply With Quote
Old June 1st, 2014, 03:08 PM   #2
Tab
Tab's Avatar
Make an attachment for a shop vac using some small hose that will fit inside the plug hole. If it's too big to go up the hose at least use it to keep it sucked to the end of the hose as you pull it out.
Old June 1st, 2014, 10:39 PM   #3
redram98
redram98's Avatar
Thanks for the information! It was cylinder 8, couldn't exactly reach in with a vac unfortunately but hit it with compressed air and some shrapnel came out. Not sure exactly how or why the plug disintegrated the way it did but didn't seem to be any noise when we cranked it over with plug hole open, fuel disabled.
Page generated in 0.20322 seconds with 32 queries
