Starter spinning backwards ?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2014, 01:39 PM   #1
Shakr
formerly square eyed rio
Shakr's Avatar
Default Starter spinning backwards ??
I want to throw this out there and see if I can catch a motor techie for advice.
My son bought a 1989 Yamaha Warrior Quad which needed some work .
To aid in understanding this motor has a flywheel on a sprag bearing or a one way bearing . The starter is a single wire and the shaft does not extend or retract its teeth mesh with a jackshaft gear set up which meshes with the flywheel .
OK we thought it needed a new starter because it would just spin and not turnover the motor , put a new starter and get the same condition.
I have read a thousand posts about this situation saying the starter spins backwards bu
t no fix to the problem .
I know the flywheel can not be installed backwards , the motor does run and once in a thousand tries it will start . I took the old starter and reversed the wires and sure enough I got the starter to spin the other way so I do know it is possible .
I can just swap the battery leads because I do not want to screw up the rest of the electrical .
I am thinking maybe a bad ground ?. does this sound possible ?.
Shakr is offline   Reply With Quote
Old May 30th, 2014, 02:05 PM   #2
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
put the start on backwards?
wave_crusher is online now   Reply With Quote
Old May 30th, 2014, 02:32 PM   #3
It was made for the southern hemisphere.
Old May 30th, 2014, 03:04 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
It would be nice if someone could put up a quad section...
Oh, we do.
http://www.greatlakes4x4.com/forumdisplay.php?f=115
Old May 30th, 2014, 04:06 PM   #5
Wehan
Wehan's Avatar
Your one way bearing is bad.
Wehan is offline   Reply With Quote
Old May 30th, 2014, 10:16 PM   #6
wave_crusher
I'll Direc your TV
Make sure the battery terminals have the positive and negative symbols on right, that they're not backwards
Old June 1st, 2014, 12:41 PM   #7
Shakr
Shakr's Avatar
battery is wired correct , ground is tight. I can use my charger and get it to run correct when reversing the wires but I do not want to burn up any components . We pull started and it will start . I have asked tons of gear heads and many have heard of this but none have a fix.....maybe thats why farm fields are full of old shit .
Also one way bearing works correctly when the starter spins correctly.
Old June 3rd, 2014, 06:18 AM   #8
RADRICK
RADRICK's Avatar
just for kicks, have you tried hooking it up to a different battery?
Old June 3rd, 2014, 06:36 AM   #9
Wehan
Wehan's Avatar
From what I've read online it is a common issue with absolutely no rhyme or reason as to why it does this..... Very odd.
Old June 3rd, 2014, 11:17 AM   #10
Paperman
Paperman's Avatar
Brush holder in the starter in wrong position? If it was clocked wrong it would energize the armature to repel the field magnets at the wrong time. Or could the field magnets be in the wrong location?
Paperman is offline   Reply With Quote
Old June 3rd, 2014, 01:41 PM   #11
Wehan
Wehan's Avatar
You may be on to something there, I watched a video about it and the guy showed the motor going backwards, he then disassembled the motor, everything was good so he put it back together and boom, worked correctly.
Old June 3rd, 2014, 04:05 PM   #12
I have nothing to add, except that I recognize (and flew) the plane in your avatar...
Old June 10th, 2014, 02:53 PM   #13
Shakr
Shakr's Avatar
I have a Crazy story about flying that plane . after a few dives, loopty loops and all that shit your pants stuff we get a 911 call from the tower asking if we can do a visual on a plane who's landing gear indicator said the wheel did not deploy ...my pilot being all gung ho says we will check er out ...... we got under the plane by maybe 30 - 40 feet ...to me looked like we were close enough to touch , the piolt asked me to unbuckle and he will get me close enough to grab the wheel and pull it to lock .....I quickly said FU .... he giggled and told the tower and other pilot everything looked good with the wheel and we did a barrel roll from under the plane to over the plane .....if you look at the handles in the old texan you will see my hand prints are probably still there.
on a side note I took the old starter apart and reassembled and it appears to be spinning correctly now , I'm going to install it tonight and see what happens .
Old June 14th, 2014, 06:31 PM   #14
Shakr
Shakr's Avatar
One way bearing was bad but I did have to take the starter apart and re assemble ;;;not changing a thing and these two combined got the SOB running ....kid is out doin wheelies and happy.
Thanks for the help ...smart ass and for real.
Over the years the names have changed a bit but the smart ass replies are still the same ....part of the reason I still come around .
Page generated in 0.42768 seconds with 66 queries
