Vent bellow - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2014, 10:24 PM   #1
Wramblerguy
Wramblerguy's Avatar
Default Vent bellow
I have synthetic gear lube in my rear axle and it keep coming out of my vent line
Idk if it because I moved the vent line to the pig (same location as the front axle)
But I was thinking of switching to a bellow
I was just wondering if anyone has run them and had any issues
Thanks
3rd generation jeeper
Old May 19th, 2014, 10:10 AM   #2
GMKLR50
Broke wheeler
GMKLR50's Avatar
I have used them a lot in a porduct I designed, we found under high heat they can expand to much and not get there shape back. That was really the only thing we found. there are diffrent material types for diffrent temp ranges but they are not easily available locally, we went to a manufacture to get them. You also have to make sure you have the right sized one so that they can expand enough or they pop.
GMKLR50 is offline   Reply With Quote
Old May 19th, 2014, 04:10 PM   #3
Wramblerguy
Well it would be on a waggy dana 44 rear
Most of the ones I see for sale on the full size 4x4 sites look about the same size
I was looking at this https://liquidironindustries.com/-VB...er-System.html
Old May 19th, 2014, 08:33 PM   #4
GMKLR50
Broke wheeler
GMKLR50's Avatar
I think your OK or at least worth the try. I think you will be fine going with a normally used one. Your not doing anything special. Just check your fluid level sense you having troubles already.
Old May 19th, 2014, 08:35 PM   #5
Wramblerguy
Thanks
It doesn't leak a lot of fluid but then again it doesn't take much fluid to make a mess
Page generated in 0.18700 seconds with 38 queries
