78 F100 351 C6 slips when cold in first. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2014, 09:10 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default 78 F100 351 C6 slips when cold in first.
Only gear it slips in is first, and only for the first mile or two, then the slip goes away, never slips from 1-2 or 2-3. Planning on running a bottle of seafoam through the trans. Then dropping the pan, adding a drain plug, adding fluid, draining, adding fluid, draining, adding fluid, and draining once more to make sure its flushed good. Any other Ideas that might be my issue, other than what I assume it is, I need a rebuild.
Old May 17th, 2014, 09:42 PM   #2
montecarlo33
The Violator
montecarlo33's Avatar
My vote is your will find gritty fluid (bad/worn clutches), which means rebuild. My truck has done that for over a year and I flushed and added 1 quart Lucas. Still runs every day. Only thing that I've found helped was letting it warm up for 10 mins before I left the house in the morning.
Old May 17th, 2014, 09:49 PM   #3
booblinker
Sore and Tired 24/7
booblinker's Avatar
I'm hoping the flush lucas gets me some time, I will only me putting 2-3k a year on this a year.
Old May 17th, 2014, 10:03 PM   #4
montecarlo33
The Violator
Its bought me a lot of time, at least in my case. Mine slips bad between first and second but only when you first take off in the morning, besides in that its fine all day.
Old May 18th, 2014, 08:06 AM   #5
chasetheface123
chasetheface123's Avatar
If you do end up needing someone to rebuild it, there is a guy in boyne, "Joes Transmission" who will do it for under $400. If you decide to go that route, I can get his cell # for you. Does great work, and turnaround time is less than 2 hours usually.
chasetheface123 is offline   Reply With Quote
Old May 18th, 2014, 10:14 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
Damn, sounds perfect, sadly its 4 hours from me.
Old May 22nd, 2014, 07:50 PM   #7
booblinker
Sore and Tired 24/7
booblinker's Avatar
Didn't flush it, just added some gunk seal sweller, and lucas stop slip, pretty much made the problem disappear, slips for a second when I first start it, before it was 30-60 seconds before it engaged.
Old May 22nd, 2014, 08:56 PM   #8
Wehan
Wehan's Avatar
@Tranny Tom
Wehan is offline   Reply With Quote
Old May 23rd, 2014, 07:18 AM   #9
Tom
Because racecar
Tom's Avatar
Needs a rebuild
Old May 23rd, 2014, 09:34 PM   #10
special ed
Pickup Agent
special ed's Avatar
Joe's Transmission is a fucking hack. He "rebuilds" a 4L60E while you wait, for $250.00 The parts cost me around 700.00, and we buy from the same place.
special ed is offline   Reply With Quote
Old May 23rd, 2014, 09:57 PM   #11
booblinker
Sore and Tired 24/7
booblinker's Avatar
While I agree a $250 isn't one I would trust, If you are paying $700 for the parts to rebuild a 4l60e it seems like you are getting ripped, unless you are replacing all of the hard parts too.
Page generated in 0.23122 seconds with 56 queries
