1995 Chevy 6.5 TD 4x4 Silverado HD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 16th, 2006, 08:00 PM   #1
xj_man_646
Wheeler-less
xj_man_646's Avatar
Send a message via AIM to xj_man_646
Default 1995 Chevy 6.5 TD 4x4 Silverado HD
Well, I just realized I am seriously hurting for money, so I am thinking about selling my truck if I can. Well, here it is:
The basics:
1995 Chevy 2500HD Silverado
6.5 Turbo Diesel
4L80E trans
4x4
120500 miles
Extended Cab
Long Bed
Dark blue exterior no rust
Dark blue interior no stains
The details:
The paint is really shiny, with normal wear and tear on the body. Scratches here and there, but you have to be pretty close to notice them. 1 dent that I know of, on the driver door, and its the size of a dime
The interior is totally un-stained, but a slight hue may be present on the seats. Either way, it is extremely clean for a 11 year old truck.
The motor starts and runs perfect, and the trans shifts very well. Motor and trans are un-modified, and have been that way since new. No chips or anything going on here.
Factory CD/casette player but I recently (last week) had all the speakers replaced with pioneer speakers by Sounds In Motion
American Racing "Baja" style polished aluminum 16x8 wheels, with stainless steel center caps and chrome lugnuts with Kelly 265/75 tires mounted on them.
When i bought the truck, there was some surface rust on the bottom of the doors and cab, but I had that fixed by a professional body shop, and should be good to go for a number of years.
Things that do not work:
4 lo does not work. The truck shifts into 4 hi and works perfect there, and will shift into lo range, but the front tires do not pull in 4 lo. I have had 3 shops tell me its the same, common problem. Transfer case switch. Simple fix, just haven't needed 4 lo, so I have not had a need to fix .t
A/C does not work right now. New compressor needed. I normally don't use it anyways, so I did not mind
Passenger side mirror does not adjust left and right, but up and down work. It is in a good position right now, so again, I haven't had to fix it
Typical wear and tear for a truck of 11 years old. There are scratches on the paint, but the truck looks real good until you get within a few feet, and even then it still looks near flawless for a truck this old.
After the body shop did the rust repair, I put the "3M Rocker Panel Spray" over the new paint to protect against rock chips. This is now peeling off, but the paint underneath is still perfect. I was planning on durabaking the rocker panels, and I will include the gallon of black, smooth, UV protected durabak that I have for the project
That is all. Somewhat minor issues, all of which are relatively easy to fix. This truck is awesome. Tows fairly well, but could use more power (what can't, right?)
Pics:
Gonna ask 7500 OBO. I have well over 8500 into it, and I bought it in June.
Located in Houghton, MI or Hudson, WI depending if I am home on holiday or not.
xj_man_646 is offline   Reply With Quote
Old November 17th, 2006, 07:48 AM   #2
xj_man_646
Wheeler-less
xj_man_646's Avatar
bumpety bump
Old November 17th, 2006, 11:30 AM   #3
BigBlueBurban
Temporary Web Wheeler
BigBlueBurban's Avatar
bump for a NICE truck. if I had the need... naw, just the money i'd be on it. someone will definantly be happy with that
BigBlueBurban is offline   Reply With Quote
Old November 17th, 2006, 11:35 PM   #4
chevybob454
454 boy
Send a message via AIM to chevybob454
pm sent
chevybob454 is offline   Reply With Quote
Old November 18th, 2006, 04:18 PM   #5
xj_man_646
Wheeler-less
xj_man_646's Avatar
Originally Posted by chevybob454 View Post
pm sent
replied
Old November 19th, 2006, 08:27 PM   #6
trick31
Sweet lookin 2500, here's a bump for ya
trick31 is offline   Reply With Quote
Old November 20th, 2006, 04:42 PM   #7
xj_man_646
Wheeler-less
xj_man_646's Avatar
thanks, man
Old November 20th, 2006, 05:58 PM   #8
BMFmike
meh.
BMFmike's Avatar
Originally Posted by xj_man_646 View Post
thanks, man
This truck is a lot of fun to get driven around in, hooray BUMP
Old November 20th, 2006, 09:59 PM   #9
xj_man_646
Wheeler-less
xj_man_646's Avatar
If i can work out me keeping it, i think im gonna ask for that chip for christmas. hello +150 lb.ft of torque
Page generated in 0.48746 seconds with 50 queries
