Laser tube cutting - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2014, 07:29 PM   #1
Tab
Tab's Avatar
Default Laser tube cutting
Anyone one on here either work at or work for a company that has tube laser cut? I'm looking at a shitload of holes in 2x3 rectangle tubing cut for me. A quick search has me on to a place in Allendale and a place in Troy.
Old May 14th, 2014, 07:30 PM   #2
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Contact @Skooter_Built He's the authority on anything to do with shitload/holes.
Old May 14th, 2014, 07:35 PM   #3
hondadirtracer
Skymaster
hondadirtracer's Avatar
We can do it at my work, Electrolabs in Fraser. http://elabsmetalfab.com/. I will pm you my boss's number
hondadirtracer is offline   Reply With Quote
Old May 14th, 2014, 08:09 PM   #4
Immortal
NO RELIGION WAT!
Immortal's Avatar
Prepare to pay out of one of your holes if you're less than 100 pcs.
It's just not fair.
Old May 14th, 2014, 08:13 PM   #5
Tab
Tab's Avatar
Cost is of little concern once you compare it to drilling a couple hundred holes with a drill press or a mill and the many, many, hours it would take me to do and what my time is worth.
Old May 14th, 2014, 09:04 PM   #6
baller
Old May 14th, 2014, 09:32 PM   #7
Tab
Tab's Avatar
baller
I have more money than time. Especially when it comes to drilling about 800 holes that all have to line up with each other side to side.
Old May 14th, 2014, 11:28 PM   #8
lgottler
lgottler's Avatar
I dont see why any laser shop should have an issue. A quick fixture and they could run a few at a time, flip, repeat. We do stuff like that all the time. We're running square holes in some aluminum 8' lengths on the cnc now if you haven't considered that option....
lgottler is offline   Reply With Quote
Old May 14th, 2014, 11:34 PM   #9
Immortal
NO RELIGION WAT!
Immortal's Avatar
True, but with a laser tube set up, there is no fixturing, sawing tubes to length, and it's faster.
Old May 15th, 2014, 07:58 AM   #10
lgottler
lgottler's Avatar
But there could be a premium to use it for simple holes, round tubing with irregular cuts on the other hand...
Old May 15th, 2014, 09:40 AM   #11
kickstand
circling the drain
kickstand's Avatar
Old May 16th, 2014, 12:11 PM   #12
Tab
Tab's Avatar
Just talked to Scott, I'll be in there next week it sounds. Thanks
It's just not fair.
You couldn't have been more wrong.
Old May 16th, 2014, 12:15 PM   #13
BlooMule
Old School
BlooMule's Avatar
It's just not fair.
Obviously, where you went the laser operator didn't waste all day surfing the interwebs.
-rw-rw-rw
Old May 16th, 2014, 12:20 PM   #14
Tab
Tab's Avatar
Apparently not. I've had a bunch of flat plate laser cut for me when my cnc plasma wasn't accurate enough and I was always surprised at the cost. Instead of taking the time to buy my plate, drive it home, load the machine, do the cutting, and do the clean up, I could just stop by the laser place and pick up finished parts for not much more than I would have into it. By time you figure a few hours of my work into the deal (time I can spend either doing my real job or getting more side work) it was cheaper for me to have the work farmed out.
Old May 16th, 2014, 12:21 PM   #15
Immortal
NO RELIGION WAT!
Immortal's Avatar
Good. Some places are outrageous. Why? I have no clue.
Laser cutting only shops are cheaper than a full fabrication shop with laser cutting.
Old May 16th, 2014, 12:26 PM   #16
I had some very fine letters cut from acrylic this winter, I was really surprised how cheap it was to have it laser cut. I used a place out west that specialized in making robot and hobby parts. They also supplied the acrylic material. It was cheaper to get ths material+laser cutting + shipping from them, that it would have cost me to buy the acrylic alone from most places.
Old May 16th, 2014, 12:31 PM   #17
Tab
Tab's Avatar
Exactly
Old May 16th, 2014, 12:36 PM   #18
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I always had stainless sheet metal laser cut and formed for specialized wash trays when I was working in diesel fuel systems remanufacturing.
Always impressed with the quality and accuracy of work, and the price vs. plasma cnc.
I know of one place in GR, might not help you since you're on the other side of the state.
http://www.laseraccess.com/
I always worked with Al Hartl there, good guy to work with.
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old May 16th, 2014, 12:47 PM   #19
Tab
Tab's Avatar
Thanks, I'll look into them too if this doesn't pan out. I travel the whole state on a regular basis so location isn't too big of a deal.
Old May 16th, 2014, 12:51 PM   #20
Please plan your personal business trips around coming to take me to lunch.
Page generated in 0.42542 seconds with 82 queries
