Ranger Outboard leaf springs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2014, 09:41 AM   #1
troyw
Default Ranger Outboard leaf springs
I'm going to pick up a 88 ranger this coming week to start a truggy. It currently has a solid axle swap done with Dana 30 front out of a YJ so leaf springs and Dana 35 in rear. Im thinking of changing the front and rear axles out to full width. If I do this will the front and rear mounting points for the leaf springs need to be moved out further. Im guessing the spring mounts on the trucks are wider than that of the ranger but I haven't seen much with people running leaf springs. Most stuff I see is all coils or coilovers. Im going cheap for now and running leafs. Any help would be great before I dive in here in a couple weeks.
troyw is offline   Reply With Quote
Old May 12th, 2014, 09:42 AM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
If you're going cheap, wouldn't it be cheaper to move the leaf spring perches?
Might still have to move the fronts outward...
Lousypirate is online now   Reply With Quote
Old May 12th, 2014, 09:52 AM   #3
troyw
Yep thats what I was asking. Since the truck already has the leaf mounts from the front turdy Im guessing the width of mounting points on a d44 or d60 will be wider so they will need moved?
Old May 12th, 2014, 09:56 AM   #4
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
Change the mounting on the axle, don't change the mounting on the frame. They will need to be moved.
It will be a lot more fab work to change make the leaf mounting different on the frame. It also could end up needing a larger amount of gusseting to keep it strong enough, depending on how much you would widen it.
lepp1892 is offline   Reply With Quote
Old May 12th, 2014, 10:02 AM   #5
troyw
Lepp that makes sense I didn't know which would be more work to move. I know its not easy welding on the axle tubes as well so wasn't real sure. Im new to leaf springs coming from a ZJ haha.
Old May 12th, 2014, 10:03 AM   #6
Lousypirate
Whoop Whoop
Welding to axle tubes aren't bad. Welding to the cast center section has a few tricks.
Old May 12th, 2014, 10:05 AM   #7
lepp1892
lepp1892's Avatar
Welding on axle tubes really isn't much different the welding any other steel. Its the cast housings on axles that is more difficult to weld.
Dang beat me to it.
Old May 12th, 2014, 10:10 AM   #8
Lousypirate
Whoop Whoop
Dang beat me to it.
Old May 12th, 2014, 10:43 AM   #9
troyw
I thought there was worry of warping if not done properly but that must have been the center housings. Im excited to start the truggy...now if I could just decide on axles I would be set!
Old May 12th, 2014, 10:47 AM   #10
Lousypirate
Whoop Whoop
You'd have to put some serious heat in them to warp them.... unless you are doing some wussy stock axles, maybe.
Old May 12th, 2014, 11:21 AM   #11
troyw
No wussy axles haha. Im having trouble deciding between a HP D44 or cheap Ball Joint D60 for the front. Tires will only be 35-37s.
Old May 12th, 2014, 11:36 AM   #12
Lousypirate
Whoop Whoop
Whatever you can get for cheaper, I'd go with.
Old May 12th, 2014, 06:59 PM   #13
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
What is a cheap ball joint 60?
Old May 12th, 2014, 07:14 PM   #14
Lousypirate
Whoop Whoop
A broken one
Old May 12th, 2014, 10:31 PM   #15
Christmas Cookie
Originally Posted by Lousypirate View Post
A broken one
Exactly...60's whether king pin or ball joint go for around the same price
Old May 13th, 2014, 07:02 AM   #16
troyw
Not in my area. People only think the Kingpins are gold down here in Ohio. Ive seen bj d60 listed for 350-600.
Page generated in 0.29127 seconds with 71 queries
