2002 superduty speedo erratic - maybe ABS module replacement - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 8th, 2014, 11:47 AM   #1
Bones
Bones's Avatar
Default 2002 superduty speedo erratic - maybe ABS module replacement
is this as big of a pain in the ass as it looks like it will be?
I am chasing a wiring/module. I have a CEL, no speedo and ABS light on. CEL is P0500. It's not the VSS on the rear diff. From what I can tell, either the VSS signal isn't getting to the ABS module (I can't confirm that) or the ABS module isn't working (isn't translating the VSS signal into something the PCM can recognise), which is fairly common.
Any tips/tricks?
Vehicle runs great, no shift issues, etc.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 8th, 2014, 12:31 PM   #2
frdboy
frdboy's Avatar
Gas or Diesel?
Old May 8th, 2014, 12:40 PM   #3
frdboy
frdboy's Avatar
Your VSS wires are red/pnk and lt grn/blk, pins 14 and 6 at the ABS module. You can ohm them and it should be the same as whatever your sensor ohms at...I don't remember right now but normally they are 700-2000 ohms. If that is fine you can hook up a voltmeter to them set on a/c voltage and make sure it increases with wheel speed.
I seem to remember fixing one with corroded wires near the module.
If you have to replace the module it will probably need to be set up with an IDS.
Old May 8th, 2014, 12:42 PM   #4
hamsmotorsports
hamsmotorsports's Avatar
Check the wire harness at the rear diff. If it's not a sensor 9/10 times it in the harness in the fist 12" from the sensor.
hamsmotorsports is online now   Reply With Quote
Old May 8th, 2014, 01:44 PM   #5
Bones
Bones's Avatar
I did replace the last 12" or so, and the plug.
It is V10 gas
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 8th, 2014, 01:50 PM   #6
frdboy
frdboy's Avatar
I have seen a few that bad ign. coils/ worn spark plugs will cause no speedo and abs light to come on. Hard to track down what coil it is without a lab scope though. It seems the coils get overworked from worn plugs or a coil just creates to much RF noise and f's with the PCM.
Old August 4th, 2014, 10:49 AM   #7
Bones
Bones's Avatar
so i have been driving this truck on and off, and now the speedo is extremely erratic.
Even when I am sitting still the speedo with sit at around 60 mph, but the speedo changes with brake pedal input (it drops lower). So I am thinking it is still the ABS module, or the wires running through the frame rails have chaffed and are shorting. Any other ideas?
Next steps might be to run new chase wires from the diff to the firewall area and bypass the factor wiring along the frame rail
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 4th, 2014, 06:15 PM   #8
frdboy
frdboy's Avatar
Interesting....
I would like to have a scan tool on it and see what the other modules are seeing for speed. Kinda sounds like a bad cluster but could also be a module messing with the signal.
Old August 5th, 2014, 08:01 AM   #9
Bones
Bones's Avatar
Originally Posted by frdboy View Post
Interesting....
at this point, i find it far from interesting. How much to drive it over to you and drink beer while you fix it?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 5th, 2014, 11:08 AM   #10
kickstand
circling the drain
kickstand's Avatar
does it beep or buzz under the dash?
Not that it matters what your answer is, because I can't help you.
But mine beeped and buzzed under the dash like mad when my speedo took a shit.
Page generated in 0.36740 seconds with 53 queries
